#15 |
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Did you ever use the manual fan and intercooler pump feature? I certainly wish the banks had that feature, I'd certainly go with them and I think it's more pleasing to the eyes.
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I have the Aeroforce gauge..was a tough decision on which to get. Only reason i went Aeroforce is the ZL1 faceplate for the gauge. If Banks had it, i would have gone Banks.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#17 |
Have you used the manual fan function or intercooler pump features? I feel most people either don't know about this or don't run their cars at the track enough to use it. Just looking for feedback
#18 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I just use HP Tuners now, but I was only aware of turning on the pump not the pump and fan with aeroforce.
#19 |
Petro-sexual
I'm not sure about anyone else, but even when brand new, my battery wouldn't tolerate storage for more than a couple weeks without a trickle charger without getting low (according to my charger readout). Given that - I'm not sure how much confidence I'd have running accessories off the battery itself. I like the idea of this feature, but it's a little iffy' for my situation.
That's only my OPINION. Ya'll might have differing experiences with the OEM battery.
#20 |
i used it once a couple years ago when the gauge was installed. I have used the CEL feature a couple times to clear a code though.
#21 | ||
#22 | |
Moderator
#23 | |
It worked well in another car but I use a manual fan switch which brings down the coolant temps very quickly, even when sitting in traffic. I have Aeroforce units in that car but it's easier with a fan the fan switch. It works well and the only time I've had battery issues was when I forgot to shut it off after parking. And that car has a 2k watt audio system. I guess there's just too much draw in the ZL1. Fair point and I will certainly take this into consideration. Thank you |
#24 | |
![]() Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
#25 | |
Moderator
#26 |
It still works well just not as fast without ice. People have cooled down their cars since the dawn of racing, the key is to take measures not to heat it back up again before a run. I'd bet that many ZL1 owners who race their cars have an aftermarket reservoir. If they don't they should consider it, an inexpensive and simple way to make cool downs much faster and very effective. Does the Banks read the important PIDS like MAT, knock, injector PW, trans temp like the Aeroforce? Does it at least read IAT2? It's not as important as MAT but still nice to know. I don't see the value of an OBD2 gauge that only reads generic emissions parameters.
#27 |
![]() Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
I have the af and thinking of going banks. I don’t need the funtiuonality of the fans but do look easier to read. I have problems in bright daylight even with tinted windows, could also be that i chose blue which may not help the issue.
#28 | |
Moderator
I’ve got my Banks reading IAT2 and IPW and I’m pretty sure trans temp wouldn’t be a problem. I also read total timing, low pressure fuel, rail pressure fuel, E content, etc. Not sure on MAT. Honestly, at the track I disconnect the Banks and datalog with HPT. Just need more info at the strip than any small gauge can give. But I find the Banks handy for street use, tracking E content, etc.
