Old 11-10-2022, 02:28 PM   #15
AROD11889
AROD11889's Avatar
Drives: 2019 Camaro ZL1 A10 Summit White
Bump it up
AROD11889 is offline   Reply With Quote
Old 12-06-2022, 09:42 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
It sucks that the oem rings are 80 something per piston or the rings from Mahle to fit are 270 plus
MAHLE 42217CP oem rings 1.2 X 1.5 .2.5 $275 to $296
OEM Rings 12661872 $85.00 ea
Rod Bolt 11548432 $4.00 ea
A good set of pistons better than oem are 850 with a summit coupon lower, includes HD wrist pins and rings
if they were like 2 0r 300 bucks might be able to justify using them in a low power build with some summit rods that fit that unusual .945 wrist pin. size.
Old 01-25-2023, 07:51 PM   #17
BMEP
Drives: C7
Does anyone know if LT4 rods are a direct replacement for LT1 rods?
Dimensionally?
Big end and small end weights?
BMEP is offline   Reply With Quote
Old 01-25-2023, 08:37 PM   #18
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I doubt the weight is the same. But if you have a rod scale and it's only a few grams you could grind some with a belt sander. Yes same journal and pin size.
What are you trying to do?
