#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Well it depends on how you classify the wing. I thought HIGH Wing meant like a non factory wing like a TRACK WING. It really doesnt matter to me as far as classing. I guess I will ask CODY to determine that. I will post back HERE his response. It seems like it would be hard for a ZL1 NOT to be in Lap Attack 3 group or faster since they are supercharged.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 04-04-2022 at 09:35 PM. |
#16 |
CLASS 3
OK guys. Thanks for bringing it to my attention.
Cody says I should be in Attack 3. I have asked him to move me over.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#17 |
Looking forward to the event.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#18 |
Should be fun. I estimate about 45 gallons of fuel LOL
#19 |
I will also be on the RT660s. Will be interesting to compare to my lap times I did on the G3Rs.
#20 |
My guess is you can probably get within about 2 seconds of your GY3R's times running the same course. I plan on starting out at about 30PSI cold on the RT660's. I expect with temps they will expand up to 36-37PSI Hot. I am running 315's all the way around but I probably WONT run my DTC70 DTC60 brake pad setup. I I will be going with stock BREMBO pads.
#21 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
The 660s will be a min of 2 seconds off the 3Rs times, imo, and are a tad better than the regular F1 3S. For sure will be interesting to see how they do!
Ken |
#22 |
![]() Drives: 2020 ZLE Join Date: Aug 2021
Looks awesome. Can't wait to see some videos! I'll make it up there soon
2020 ZLE A10
Rotofab, SPL suspension goods, Cobalt XR1 pads, Apex wheels |
#23 |
The RT660s turned out to be 4 seconds slower than the G3Rs on the 3.1 mile track. They were still good enough for me to grab 1st place in class.
#24 |
![]() Drives: 2022 2SS 1LE Join Date: Nov 2021
That extra -1 of camber must really make a difference in poke?
I am running a 20x11 w/ 26mm spacer w/ 305 30 20 SC3 square with -2.5 front and am getting a lot of poke up front. You must be super close on your inside strut? |
#25 | |
I used the stock BREMBO pads and my guess is I simply got them too hot causing some pretty severe brake fad. In looking at the pads later I should have changed them out PRIOR to this race and I flat just missed it. I thought I had brought my spare set but I was mistaken. Next track event is SCCA track night at EAGLES CANYON NEXT saturday. They run that in conjuction with the Time Trails that runs BOTH Saturday and Sunday. Hope to see you there.
#26 | |
The wheel is TOO close to the strut without the spacer. There was MAYBE the thickness of a piece of paper clearance if you DO NOT use the 5MM spacer.
#27 |
I'll be doing the SCCA TT at ECR
#28 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
But that's really interesting because Chevy only uses 11mm offset on the 19x11 front wheel of the ZL1/1LE using 305/30/19 front tires. So they are being really conservative and there seems to be a bit of room to play with there if you could get away with a 1/2" less wheel/tire radius and 9mm more offset.
Matt Miller
2020 SS 1LE |
