#15 |
Monterey County Camaros
Drives: Stock 2016 Camaro V6 Join Date: Nov 2019
Adding power is one thing but cut some weight out the car to make better use of it. I was able to cut out quite a bit. When the roll cage and passenger seats were out car was 3,230 pounds with a 1/4 tank of gas.
Haven’t been able to take it to a strip but onboard computer put me at a 4.6 0-60. I think with the RPMs closer to 3k it would be closer to 4.4 with close to 160,000 miles.
#16 | |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
Current:
2020 V6 A10 - looooving the regular unleaded, over 20mpg, and excellent daily driver manners!!!!! Past: 2018 1SS 1LE - stock 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
#17 |
I’ve been running 91 for years. Better timing, better spark, smoother overall performance. And top tier gas only. Hit 160,500 miles the other day and the car performs better than when I first bought it. Just keep up on maintenance
#18 | |
after the cai install i felt a tad bit of power/pull which i was pleasantly surprised by, However, i am not liking this exhaust and i really dont want to take it off and pay for another one. Do you think maybe adding a magnaflow resonated x pipe or something of the like remedy the 4 banger drone i am hearing? i originally wanted to go with the flowmaster american thunder like you have but i ended cheaping out instead
Current:
#19 | |
This company does sound clips with their installs. May be able to find your combination searching through videos https://youtu.be/CTfEq1jtlY0?si=hlmZqCgHERT3YqAc
#20 | |
thanks for the range device tip. never even heard of such a device!!!!
Current:
#21 | |
![]() Drives: 2019 Camaro V6 manual Join Date: Jun 2020
80mm Overkill tb and Tune, aFe CAI
Charger R/T |
#22 | |
BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Does not require tuning. Warranty safe. • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications • Easy Installation (15 Minutes or Less)
Current:
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
A trifecta type tune will be more effective than a cai, throttle body changes, exhaust, etc that dont involve retuning. But it's less about adding power than changing how the car responds as it shifts...but it may only be super effective for <2017, so it includes the tcm tune too. Not sure if they ever broke the protection on newer tcm's.
The lgx in the camaro is operating at basically peak NA performance. You need forced induction or different fuel (E85/nos) to improve performance ....or weight reduction or better tires. I dont recommend spending money on anything else if power is your goal. You'll be chasing fairies. |
#24 |
![]() Drives: 21 Camaro V6 manual Join Date: Aug 2025
I would not get a tune but I have a manual transmision. Run premium fuel , it will run better and be healthier. I replaced the factory 20-8.5 wheels,30 lbs, with tsw 18-9 , 19.25 lb wheels and 255-45-18 Bridgestone potenza tires. It drives and handles much better. Keep the MAF sensor clean.
#25 |
Yes, I also have a manual with lighter 20 lb wheels.
Charger R/T |
#26 |
The 245-40-20 and 255-45-18 tires were Bridgestone potenza, both weigh 26lbs. The 18 has 250lb more weight capacity, drives much better and costs less. The weight savings comes from the wheel and the tire size performs much better. I put over 20k miles on the 20" Bridgestones a now have 5k miles on the 18" Bridgestones
