Old 03-29-2022, 10:56 AM   #15
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Originally Posted by Wyzz Kydd View Post
I thought you had to engage no lift shift from a stop. Are these guys just rolling down the road and using it on the fly?
There is no advance step needed to engage NLS. It works by rpm and throttle position. If you have your foot to the floor (and don't lift at all which is hard for me to do because of 40 years of right foot muscle memory during a shift) and the rpms are above 6200 rpm for a regular SS and I believe above 5000 rpm for 1LE and ZL1 then NLS will work.
Note: Don't hold me to those rpm targets as I am going off memory. When I try it which is rare because my right foot just wants to twitch - I always shift right below redline - 6400-6500 rpm.
476 rwhp/440 rwtq (sold)
Old 03-29-2022, 11:13 AM   #16
MarlonP
MarlonP's Avatar
Drives: Future Camaro LT1
Do the LT1 have the NLS feature too?
2022 Camaro LT1 6MT Shadow Grey Metallic NPP
1/24/2022 - 1100
3/22/2022 - 2000
3/23/2022 - 3000
3/30/2022 - 3300 TPW 4/18
4/07/2022 - 3300 TPW 4/25
4/13/2022 - 3300 TPW 5/2
4/20/2022 - 3100 TPW 5/2
4/26/2022 - 3400 TPW 4/18
5/05/2022 - 3800
MarlonP is offline   Reply With Quote
Old 03-29-2022, 11:15 AM   #17
NLS enable rpm thresholds are more permissive, check this post from Al Oppenheiser for a detailed description: https://www.camaro6.com/forums/showp...61&postcount=1 . The software enables NLS above these thresholds, if you press the clutch, it will hold rpms at the target until you complete the shift. Not sure if there is a time limit for doing so, but I doubt people want to test that out on their own transmissions
Old 03-29-2022, 12:17 PM   #18
SSDan
SSDan's Avatar
Thank you!
I knew there was a chart out there somewhere and as you can see my memory is faulty. I forgot there was an enable rpm and a target rpm.
As the chart shows the NLS feature is available across model lines regardless of engine type.
I would believe that those with the LT1 model have the feature too.
Old 03-29-2022, 12:46 PM   #19
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
That's good to know. Thanks.
Wyzz Kydd is offline   Reply With Quote
Old 03-29-2022, 04:45 PM   #20
buckwam
Drives: 2021 camaro 1ls
I assume the target rpm for the LTG should be 5400?
buckwam is offline   Reply With Quote
Old 03-29-2022, 09:35 PM   #21
Motor Fast
Drives: 2018 Camaro SS 1LE
Originally Posted by Christian1LE View Post
Pretty much, I've played around with both but now I just always NLS.
That's pretty good. I sometimes lift by mistake out of habit.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
