#15 |
![]() Drives: Chevrolet Camaro 2SS 1LE Join Date: Feb 2022
Oil consumption is usually caused from the inverse. Excessive low engine speeds, sustained speeds with no load, etc prior to rings sealing. Many times the top ring will seat well, but the ones below end up not seeing enough cylinder pressure to seat them. I suspect much of the 1500 miles they recommend is not for things to break in, develop wear patterns etc. I personally think it's a buffer to minimize damage if something wasn't assembled or manufactured quite up to par.
I've physically watched engines break in on a dyno with everything including crankcase pressure being monitored. If those rings arent seated in a handfull of pulls, those engines never seal like they should. Roller cams don't "wear in" like old flat tappet cams either. If a twin disk clutch isn't seated in a few hundred miles, it's a pile of junk or defective. The mechanical side of these cars should be worked in by 500-750 miles plenty good enough to take whatever it was built for. Do as you wish though, it's your ass on the line if it breaks, lol. As someone who has torn apart, assembled, and criticaly inspected piles of engines, transmissions, and rear ends I've never seen any mechanical vehicle part that needed 1500 miles before it was broken in. We must be driving automotive unicorns here, lol. I'd change engine and gear oils much sooner than recommended. You'll be just be regurgitating the fine metallic particals after the first few hundred miles. The oil filter will catch most of it, but clean fresh oil is a good thing any way you shake it
2022 2SS 1LE, 6MT, Black, PDR, Sunroof, Nav, Alloy Pedals, SS Console Lid, Black Camaro Fender Emblems.
#16 |
![]() Drives: 2022 ZL1 1LE Join Date: Jan 2021
I also have a 2022 ZL1 and I just went back and looked at the 2018 ZL1 owners manual and it is written the same way as the 2022. On pg 209 it only mentions the 1500 mi break in procedure for under 4k rpm etc. There is no mention of the 500 miles. Since majority have been doing the 500 mile under 4k rpm and then drive it like they stole it after that…seems like they aren’t having problems. That’s my plan…500 mile oil change, then drive it like it’s meant to be driven…then change oil and rear diff at 1500 and then sign up for my first track event.
2022 Red Hot ZL1 1LE
1972 Chevy Nova Sold: 1997 Z28 Camaro 2000 Corvette |
#17 | |
The most likely explanation is that gm simply doesn't care enough anymore to spend resources on keeping things up to date. The peak for the Camaro was the 2018 ZL1 1LE Nürburgring run, their level of attention been downhill since then.
#18 |
Thanks everyone for all the info. I guess the general consensus is there is not current documentation on this and everyone is just going of the older documentation that is for the same car. I feel at the end of the day the engine is pretty bullet proof and you would almost have to try to mess it up. I think from the feedback here Ill wait till 1000 miles and then also have them do the diff oil as well. see my stupid questions let me find out new info I otherwise wouldn't have known
thanks guys.
#19 | |
Thank you Al Oppenheiser!
![]() And yes it also refers to the 500 mi oil change. So yeah that's why the OP is getting recommendations for the 500mi change from us old-timers.
#20 | |
[QUOTE=Gunkk;11151380]
That said, I'm sure it's valuable to everyone in the thread, and almost sure there's no reason for these recommendations to have changed for 2019+, the essentials of the car remained the same.
#21 | |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
Early oil changes are important in this context, as well as the diff fluid. It's a $70,000 car that will likely never see high mileage. Don't cheap out on oil changes. Last edited by Mark R; 03-25-2022 at 04:27 PM. |
#22 |
![]() Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD Join Date: Nov 2021
Is engine map different during break-in period? I think I read somewhere that fuel economy will change after that which would suggest it.
But my problem is that my car is super weak on low RPMs - I need to pump it to 1.5k to comfortably start going on 1st. I would expect to be able to move car around on parking lot without touching gas pedal but it's not possible. And it's not my first manual car. My first 650HP manual car. I learned stick while learning how to drive, and practiced this over 10 years driving only manuals... It died on me like 5 times within first 3 days. As I said anything under 1.5k seems weak - RPM dips almost to stall. Normal for break-in period?
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover Charger sold! Better to sell, than waiting to be stolen... |
#23 | |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#25 | |
#26 |
![]() Drives: Chevy ss sedan, 22 ZL1 vert Join Date: Jul 2021
I have several manual cars, my zl1 manual did take me a few days to get used to, I slowed down my clutch release compared to other cars taking off normal from a stop and seemed to help me. In my driveway moving car around no throttle needed to get moving to full release of clutch slowing down release, torque of motor gets it going no bog.
#27 |
I think you are just getting used to it. Muscle memory kicks in and you get the clutch engagement point and throttle just right. That is part of the fun of driving a manual, a bit more challenging but rewarding when you get it just right.
#28 | |
My yesterday's joy ride was almost flawless
