03-14-2022, 11:08 AM | #15 | |
This one seems to be adjustable only after unmounting entirely from the wall, which is going to be a pain, as you have to drill into studs again, plus your adjustments will be limited to your stud spacing.
03-14-2022, 11:13 AM | #16 |
arpad is correct. My width is set by stud spacing. I went to the maximum width and into the studs with lag bolts. I mounted mine about 7 ft up on my garage wall (10 ft ceiling) and use a block & tackle (also from amazon) to hoist the wheels up and down. A slight PITA, but it's very much out of the way up there.
03-14-2022, 12:01 PM | #17 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I wanted to do a wall mount but I just dont have the space for it on a wall or on the floor, small 2 car garage with 2 cars crammed in it, work bench and so on. I keep my summers in the man cave instead. The winters go under the deck and tarped (deck is enclosed).
03-14-2022, 02:05 PM | #18 | |
Drives: 2021 LT1 Join Date: Aug 2020
Oh yeah, you're right (I just checked mine). |
03-14-2022, 03:29 PM | #19 |
Who Needs to KNOW?
On older cars w smaller wheels and tires, overhead was good idea, but these wheels tires are are about 60 lbs EACH.
My solution: I stack them on bases of old office chairs. Easy to roll around. Often free on market place or your attic.
ing for grip.
03-14-2022, 05:31 PM | #20 | |
Your solution isn't bad at all, I just didn't want to surrender the storage space I now have under the tire rack.
03-14-2022, 05:34 PM | #21 |
Definitely looks like it…only $50 less than I paid since I’m a sucker lol…
03-15-2022, 08:09 AM | #22 | |
through the miracle of physics, I can actually control the weight of one wheel with a single hand. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
03-15-2022, 08:28 AM | #23 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Really pains me to see those just sitting there in the rack. Makes me what to drive down an pick the up. With gas prices though, shipping would be cheaper. |
03-15-2022, 01:42 PM | #24 |
Drives: 2022 LT1 Join Date: Jan 2022
I use this.
https://www.amazon.com/MaxxHaul-8074...s%2C140&sr=8-6 It is very easy to roll around the garage if it gets in the way. |
03-15-2022, 01:44 PM | #25 |
I could haul them up to CamaroFest for you, if you can wait till then and you're planning to go anyway. Think I can fit them in the Camaro if I drive solo. Hm?
03-15-2022, 01:48 PM | #26 |
03-15-2022, 02:07 PM | #27 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I would kill to have a garage to use one. lol
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
03-15-2022, 07:46 PM | #28 |
/zips up flak jacket and puts on helmet
