Old 03-10-2022, 06:50 PM   #15
s346k
s346k's Avatar
Drives: like an old lady
my experience with this topic is as follows
ive used (fresh) oem, rp synchromesh & redline d4
the trans feels best with fresh fluid. ~6 months after changing fluids, the trans goes back to being clunky. always shifts good at wot, never any real issues other than it's just clunky.
no winter use, not a dd. i change trans fluid every spring.
its my experience that it doesn't matter what brand you use. initially the trans will feel great but eventually go back to its tr6060 ways.
Old 03-11-2022, 08:29 AM   #16
hakank14
hakank14's Avatar
Drives: 2022 Camaro 2SS 1LE M6
Originally Posted by 6spdhyperblue View Post
Who has used that in the M6?
Also interested in hearing more about the Mobil1
hakank14 is offline   Reply With Quote
Old 03-11-2022, 08:40 AM   #17
hakank14
hakank14's Avatar
Originally Posted by soloknight6 View Post
I used Amsoil, a much better shift feel over the stock fluid.
My current lean is definitely the AMSOIL. Appreciate it!
Old 03-11-2022, 08:40 AM   #18
hakank14
hakank14's Avatar
Had a feeling this may be the case. Appreciate your input.
Old 03-11-2022, 08:55 AM   #19
BrandanK
Drives: 2021 Camaro SS 1LE
There is a thread in the Facebook 1LE Group. I cannot link it here as it is a private group.
The thread has about 50 replies, a few have used the Mobil 1 HP ATF with good success.
BrandanK is offline   Reply With Quote
Old 03-11-2022, 09:01 AM   #20
ZPirate
ZPirate's Avatar
Originally Posted by Warrior102 View Post
OEM sucks, sucks harder when it's cold. I've tried Mobil1, Redline D4 and Royal Purple Syncromax (all better than OEM) but the Syncromax is the smoothest shifting 1 - 2 and everywhere in between. You can get a six quart case on Amazon for under $100, takes just under four.
Looks like you have tried almost all the options. Thanks for the feedback.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 03-11-2022, 09:50 AM   #21
6spdhyperblue
Drives: 2SS 1LE
I thought dex6 and potentially hp lv was a thinner viscosity than dexiii. Obviously will need to do some digging and confirm. I would be extremely careful to not go thinner than oe.
I use rp synromesh and remember it being higher viscosity @ operating temp than oe when I last looked. I noticed little to no trade off in cold weather performance.
There are records of people using rp redline and amsoil back in the t56. Over 20 years of testing. I’m not sure I would risk being a geinea pig at this point.
I’ve only tried Mobil 1 dex 3 and rp. I did not like how notchy the M1 was and drained it
Old 03-11-2022, 11:17 AM   #22
BrandanK
Thanks for the insight. Let us know if you find anything on the viscosity.
BK
Old 03-11-2022, 05:20 PM   #23
6spdhyperblue
Drives: 2SS 1LE
Mobil 1 dexron 3 (also almost every brand dex3 I found is 7.1-7.5)
kinematic viscosity @ 100*c(hot) 7.4
@ 40*c 36.3
Density @ 15.6c g/ml .846
Mobil 1 hp lv bottom (and yes seems similar to dex6)
kinematic viscosity @ 100*c(hot) 5.7
@ 40*c 27
Density @ 15.6c g/ml .835
Old 03-11-2022, 06:16 PM   #24
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I also think Amsoil is pretty nice. Worked well on the track as well.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 03-11-2022, 08:43 PM   #25
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I'm loving the Mobil1 ATF
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 07-27-2022, 12:13 PM   #26
asthmamax11
asthmamax11's Avatar
You guys remember on the C5's how GM said it was "lifetime" fluid?
Transmission was sealed
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 08-01-2022, 10:34 AM   #27
paradigm
Drives: 2022 Camaro 1SS 1LE
Should I be changing the 1LE M6 fluid after break in around 1500 miles ? Or if not, how long can I wait?
paradigm is offline   Reply With Quote
Old 08-01-2022, 12:04 PM   #28
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
If you're not taking your car to the track just follow the manual, I wouldn't worry about it for a while. Track use I believe is 12 or 24 hours of track time.
Christian1LE is offline   Reply With Quote
