Old 03-09-2022, 10:39 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by 1LEornothing View Post
Would a good tune on E60 instead of 93 oct have prevented this?
Without a doubt. 93 octane is piss water for stock compression LT1's running boost. If you want to run 93 then lower the compression.
One thing to also consider is proper crank case ventilation. Need at least a metco valve cover breather with check valve disk.
Old 03-09-2022, 10:54 PM   #16
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
+1, afaik LT1 can be subject to LSPI, low speed pre-ignition which is a bad form of knock DI motors are subject to under extreme conditions like boost + high compression....
Old 03-09-2022, 11:18 PM   #17
laynlo15
Drives: 2022 Lt1 A10
I feel your pain, been there with both the front and rear seals. Costs a bunch of money for making some bad choices on too much boost and timing. We were running MS109 but just didn't have enough crank case ventilation. We actually broke number 1 and 8 ring lands. Sorry to hear that but many of us have had this happen. I would build the new short block with 10.0 compression if you intend to run boost. Ended up building 10.0 forged Manley short block. Good luck on your choices.
Old 03-10-2022, 05:50 AM   #18
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Don't want to add to your misery but I seem to have read that the piston ring gap on the LT1 is a bit tighter than the previous Gen4 LS engines and more suseptable to breaking pistons with boost.
Spaceme1117 is offline   Reply With Quote
Old 03-10-2022, 06:56 AM   #19
cjperformance
cjperformance's Avatar
What did your logs look like when it blew? Im curious about timing, AFR, manifold air temp, etc on that pull. May help to identify the exact circumstances/tune that spell out engine death.
I ran the canned procharger tune for a while (big mistake, lol, see my other thread), and did 93 octane for a bit before stepping up to an eth mix. Comparing yours and mine at the time might be helpful. If the tunes were similar, could point to just physical differences that make one engine live and another fail.
Im running around E50 for the most part and getting 8.5 to 9.5 psi in colder weather. Im wondering if I'd kept my 93 tune in the denser air if I'd be in the same boat right now. On the other hand it would be the excuse i needed to go through the bottom end and beef it up.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 03-10-2022, 07:01 AM   #20
cjperformance
Disclaimer: this is JUST my own understanding. This has been a suspected potential issue for a while, but some other well known tuners on this board have somewhat debunked this. The rationale is that butted rings should have scored the cyl walls, but doesnt seem to be the case. Evidence seems to point to just manufacturing difference and luck.
Old 03-10-2022, 08:06 AM   #21
laynlo15
On my Manley forged motor we build after the stock Lt1 expired we opened the ring gap up to Manley's recommendations for a boosted engine. Expansion of the ring gap is an issue for the Lt1 when you want to make more boost then GM has it set up for.
Old 03-10-2022, 09:30 AM   #22
Kerry
Drives: 2019 2SS Camaro
Its luck of the draw on stock pistons. 2 engines I had were 11 thou on the top ring.
When the front seal blows u will have blow by from a cracked ring land between the top and second ring, most likely.
If the rings butted enough to break the piston it would not have a perfect bore. Some scaring would occur. Happened to me. I was about 600 miles from home and drove it in. All I had to do was put in a set of Wesco's. No one had a drop in set at the time . That was about 20000 miles ago at about 700 wheel. Bore was in perfect shape. No hone no nothing. just gapped the rings to Wesco specs, I did put in the ls3 front seal. Did it with the engine still in the car. Not that bad really.
Now the damage can be much worse depending on the piston and how much damage.
I had another motor with over 20000 miles on it. Sized the number 8 rod making over 600 but pistons were perfect. Put a crank and 2 new rods used all same pistons and ran perfect.
Its crap stock pistons. some are better than others. Even some stock cars have broke ring lands.
Kerry is offline   Reply With Quote
Old 03-10-2022, 11:31 AM   #23
Crazy Drywall Guy
Drives: 2018 Chevy Camaro 1ss
Well after talking to my tuner today it appears I hit 11 psi at 6800 and he seen some detonation. I purchased the P1 procharger lightly used with 3.7 upper pulley . I called procharger direct before installing the unit and they said my setup was good for 8-9 psi and with headers would be closer to 8psi. Budget build ideas please!
Crazy Drywall Guy is offline   Reply With Quote
Old 03-10-2022, 12:55 PM   #24
wnta1ss
Drives: 2017 Camaro 1SS
As far as the ring gaps in a stock LT1, we've heard of ridiculous top ring gaps in these things, like .007" or .009", while others have reported .011" or even .015", so luck of the draw applies to some extent. Luck of the draw is because you cannot tell what you got from the factory without disassembling the engine.
Old 03-10-2022, 01:07 PM   #25
cjperformance
Ouch, yeah, I'm getting 8.5 to 9.5 psi with a 4.13 pulley in the cold weather. There was another person on the forum that was getting 1 to 2 psi higher than what procharger said too.
So unexpectedly high psi + detonation on 93 octane would likely kill it regardless of ring gap.
Old 03-10-2022, 02:51 PM   #26
Smokin19
Drives: 19' ZL1 A10, w/pdr
Was thinking the same thing. Do you think a MM can helps in this regard?
Smokin19 is offline   Reply With Quote
Old 03-10-2022, 04:28 PM   #27
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The MM Wild can works well. I’m running that with the stock LT1 crank seal with no issue.
Old 03-10-2022, 05:39 PM   #28
Kerry
Knock sensors should stop any damage unless they are tuned wrong. With in reason of course
