Old 02-21-2022, 06:44 PM   #15
JSH
JSH's Avatar
Drives: '20 ZLE
If you've done this a 100 times you don't need to review any steps, but if you haven't done it at all or only done it a few times, you can't write too much detail into these steps. After all, it seems the OP has never done it
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-22-2022, 08:49 AM   #16
CanadianVetZL1
CanadianVetZL1's Avatar
Drives: 2021 Chevrolet Camaro ZL1
12) Rocket transformer program initiated in:
13) 3
14) 2
15) 1
2021 Camaro ZL1
ADM S/C Expansion Tank
Dual Aeroforce gauges
Eibach Pro Lowering Kit
Oracle Side markers (Paint matched)
Rear window "wind screen"
Xpel Paint Protection
Ceramic Pro Coating
CanadianVetZL1 is offline   Reply With Quote
Old 02-22-2022, 09:42 AM   #17
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
If you've done this a 100 times you don't need steps 1 through 8 but if you haven't done it at all or only done it a few times you times you can't write enough detail into these steps
I agree. I have done this well over 200 times on my car and I don't even think about it.
Old 02-22-2022, 01:46 PM   #18
brad65ford
Drives: 2018 Zl1 Camaro
Well i give up, my car is not everyone else's. I've attempted multiple times as what has been suggested, still will not start unless I unplug the battery. Its the norm for me to re flash.
brad65ford is offline   Reply With Quote
Old 02-22-2022, 02:01 PM   #19
laynlo15
Drives: 2022 Lt1 A10
I'd say between all my Cars since the 2016 1ss I have for sure flashed these cars well over 140 times between dyno and reflashes at the track or on the street logs. Last year at the May NMCA I probably flashed my C7 at least 12 times in 3 days after logging every pass running 2 classes. Could do it in my sleep. I finally had to delete some downloads.
Old 02-22-2022, 04:27 PM   #20
Kerry
Drives: 2019 2SS Camaro
Originally Posted by MartinLe View Post
1) with ignition off, connect HP Tuner to OBD port.
2) open editor and select file to flash (I always make sure nothing is running on
the computer except the editor)
3) push start button - with foot off brake - until all dash lights come on
4) select write calibration
5) after writing process is done, turn off ignition for 10 seconds
6) turn ignition on for 10 seconds -do not start car
7) turn ignition off for 10 seconds
8) start car.
With this sequence, I have never had any problems.
Ck engine light should be on indicating that its in service mode to do flash. This is exactly how I do mine as quoted above. If after I flash and do not go into acc mode key on key off then back on then it will start. If i just turn off then back on and try to start all it will do is clunk once. Then just turn off and back on hit break and it will start
Kerry is offline   Reply With Quote
Old 02-22-2022, 04:31 PM   #21
Kerry
Also on my vert. almost every time I flash it gives me a lost communication with tcm I think. So Iv got in the habit of clearing codes after a flash while Im still in service mode,in the scanner. My coop did not do that. No problems I just clear it out.
Old 02-23-2022, 07:09 PM   #22
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
I have always done it as I described it and never had any issues. Just to be clear, the "ignition on" selection is not the same as the "accessory on" selection. But, if your car is accepting the write with your method, I wouldn't worry about it.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 02-24-2022, 09:22 AM   #23
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Happened to me every time my Tuner would flash a new tune. Would not start and if it did it ran like crap. Unhook the battery and all is good.
dmcmahan60 is offline   Reply With Quote
