Old 01-24-2022, 09:15 PM   #15
clg82
Drives: 2020 Camaro ZL1
8 years from model year date of the car until first smog, every 2 years after that I believe.
Op, I'm hear in socal with similar upgrades that you're looking at. Your ever wanna hear and see how it feels, wouldn't mind getting together for a drive with some other camaros in the area
I’m in for a drive, and also to get your smog guys phone number
Old 01-24-2022, 09:24 PM   #16
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Hahahah shhhh!!!!
Mac7504 is offline   Reply With Quote
Old 01-25-2022, 05:31 AM   #17
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Ha I still have 4 years, hopefully they're still around then
Old 01-25-2022, 06:47 AM   #18
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Hey There...
Im still breaking in my ZLE and while I slowly rack up the miles, and follow the process, i wanted some feedback on a mild build plan.
WANT: More Noise + More Reliable Power.
POTENTIAL PLAN A: Rotofab + AWE Touring catback + E85 FlexFuel Kit + ATI Overdrive Damper.
QUESTION.1: How much am I leaving on the table by hold on Long Tubes? I dont want the car to be too loud.
QUESTION.2: What can I expect with PLAN.A RWHP?
QUESTION.3: What else should be on my radar? Catch Can? Plugs? Ported TB? Kong SC?
Thanks in Advance
If you are not worried about smog, I would do Rotofab intake, E85 sensor, Kooks 2" long tube headers with cats into the stock NPP exhaust. Skip the AWE. And then of course, a tune.
With the long tubes and NPP, you will have the best of both worlds; quiet when cruising, loud when you get on it.
As far the ATI damper, I'm not a big fan of dampers unless its a max effort build.
I have just a regular SS with LT1, and I picked up over 40 hp with just E85. Your car should pick up more being supercharged.
Rotofab is usually good for 10 to 15.
But headers make a huge difference; not just in peak power but extending the power and torque curves.
Headers on my car picked up about 25 peak hp but was about the same peak tq. The big difference with the headers was massively extending the upper rpm hp and tq curves after 5000 rpm and much more area under the curves. At 6500 rpm on stock manifolds and tuned, my SS was at 350 hp and 290 tq. After headers at that same rpm and tuned, it was 410 hp and 330 tq. That's 60 hp and 40 tq difference at the same upper rpm.
Spaceme1117 is offline   Reply With Quote
Old 01-25-2022, 07:26 AM   #19
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great feedback! Thanks for sharing… So then I’ll plan to do headers first and see how I like it before considering the AWE set up. As for the headers, considering this is a mild build, should I get the 2”?
Also, don’t all those bolt ins and E85 require a tune?
Old 01-25-2022, 10:16 AM   #20
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
I'm in for a drive too Aaron. I'm getting tired of driving the Blackwing (will be taking it to OC Autobahn on 02/06) . The ZLE needs some exercise.
Old 01-25-2022, 10:18 AM   #21
Evansa22
Evansa22's Avatar
Yes e85 requires a tune at the very least to turn it on in the ecu. Really anything outside of a cat back, intake, and throttle body would need a tune. Also a tune would benefit any mods to make the most of them.
Headers aren't bad to install and could be done in a day on jackstands. You'll be able to run a good amount of ethanol, and make some good power. A ported throttle body is a good idea, I actually have one sitting in the garage you could "borrow" in case I ever need it back.
Old 01-25-2022, 10:23 AM   #22
Evansa22
Evansa22's Avatar
Haha the turbo spool fun only lasts so long. I might be able to make it out, but really want to hit the mountains and desert, not the beach. I'm down for getting something together. Maybe I'll post up something in CA section.
Old 01-25-2022, 11:16 AM   #23
clg82
Let us know if you do!
Old 01-25-2022, 12:41 PM   #24
Spaceme1117
Oh yes, you definitely need to get a tune.
And for header size, I would do 2" since your car is supercharged. But 1 7/8 size would be fine also.
Old 01-25-2022, 01:06 PM   #25
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Mac7504 View Post
Those mods require a tune and a tune is an automatic fail here in CA now. Makes me sick.
Yup. That's my understanding. What I'm still foggy about is the flash count, and if that matters. I was almost hoping my '16 Sonic needed a smog this year, but it didn't, so I don't yet know.
No, from what I understand once you tune, you've essentially cracked the oem pcm.
And its every 2 years after the first 5 years. I can't recall off the top of my head but my older cars are every 2 years.
I think it's 8-years. My '16 Sonic wasn't required to smog this year, so I think it's 8.
8 years from model year date of the car until first smog, every 2 years after that I believe...
this
'20 ZL1 Black "Fury"
Old 01-25-2022, 01:13 PM   #26
Mac7504
Mac7504's Avatar
From my understanding, speaking with my smog guy is if it was something (flash/update) performed by dealer, it get tied into your Vin and its not really overwriting the entire pcm. But like you said, since it's relatively new, there is some confusion going around.
I hate that bs rule!!!
Old 01-25-2022, 01:17 PM   #27
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If the flash does matter, those of us keeping these cars are going to have to get PCMs, lol...
Old 01-25-2022, 01:22 PM   #28
Mac7504
Mac7504's Avatar
Ecu/pcm whatever u want to call them.
Or other means.....
https://www.google.com/amp/s/www.mot...fications/amp/
I doubt hp tuners or many others are carb certified.
