Old 01-17-2022, 10:45 PM   #15
Dabjbr
Drives: 2020 SS 1LE
Paint came out perfectly.
*Sand all parts w 400
*Use SEM prep spray or acetone w lint free cloth to clean
*Adhesion promoter spray
*Tack cloth very light so not to leave residue of tack on
part
*Primer several light coats 10 min apart
*wait 30 minutes to wet sand if needed or applying the.
color of your choice
*spraymax 2k paint with hardener or regular enamel paint then follow up with 2k gloss or matter with the hardener either way I think it's best to use a paint w a hardener.
You could even prep the parts and take then to a paint shop and have them spray them with left overs from a job with even better hardened paint.
The lights remove easily from the frames with a solder iron. Just pull while you heat.
That is a little more involved than I hoped. Lol
My preference was to do the door ‘blades’
I originally thought wrapping it in red alcantara would look and feel great but maybe I first try painting it red. Then, if it doesn’t look good, I can wrap?!
Btw, I have a 1ss so no spectrum lights for me :(
Dabjbr is offline   Reply With Quote
Old 01-18-2022, 04:20 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Non lighting is 200 painted by GM..
Spectrum lighting colored is 650 in red or blk.
After supplies you would be paying 100 more I'd get the prepainted ones.
Old 01-18-2022, 09:43 PM   #17
Dabjbr
Drives: 2020 SS 1LE
Great point. When I make the move, I’ll either wrap in red alcantara or just buy painted ones. Thanks bud.
Old 12-03-2022, 05:35 PM   #18
19RSVert2.0T
Drives: 2019 RS Convertible 2.0T
Do you have to remove the door panel to remove the trim piece that is silver on the door? Or was that just because of the lighting?
19RSVert2.0T is offline   Reply With Quote
Old 12-03-2022, 05:56 PM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Yes, watch the video from lethal garage to remove panel, then take white cloth material off(very easy) then it's like 8 screws and wire connector. Next if you have lighting a solder iron to heat plastic tabs while lifting to separate light bar from plastic.
Old 12-03-2022, 06:19 PM   #20
19RSVert2.0T
Thank you, any tips for the pieces around the vents and behind steering wheel?
Old 12-03-2022, 08:43 PM   #21
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
The knobs you turn for temp just pry off easily, same with parts on dash cluster. The panel ac vent on the upper dash u have to take off the dash insert, and on the panel behind wheel you just pry the gap to separate the panel to get to back side of ac vents tabs. So upper ac vents have tabs to unlock from back side in other words. I want to do something about the door handles now.
Old 12-06-2022, 01:14 PM   #22
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Nice execution. I would have gone yellow since so much of the body is visible with the door open, but I like consistency. That said, I get how the stitching made it a difficult decision.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 12-06-2022, 02:53 PM   #23
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I bought a bunch of zl1 1le parts so I can make yellow or satin blk now
Old 02-17-2023, 09:23 AM   #24
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I bought these spare parts incase I wanted to go back to stock this might give someone an opportunity to have no down time customizing theirs. 200 plus ship
As you know I sold my car..
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
