#15 | |
![]() Drives: 2018 2SS 1LE Join Date: Apr 2019
I was caught out in the thick of it last year from Pilot Mountain thru Fancy Gap. Thankfully not in the 1LE, lol. Are all the new lots staying pretty empty down there? Curious if Hendrick is marking them up much. Ouch! |
#16 | |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
#17 | |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
#18 | |
![]() Drives: CHEVROLET CORVETTE Join Date: Feb 2021
#19 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
I see most are following the owners manual, and in this regard the instructions can likely end up with two things. #1 is oil consumption issues as the piston rings never had the driving needed to properly seat them. This takes place in the first few hundred miles. After app. 500 miles a hard glaze forms covering the crosshatch abrasive hone pattern we cut in order to abrade the rings into the shape of the cylinder walls. No, or nearly no seating occurs once the glaze forms and then only a disassembly and re-hone can it be given another chance. So look at these pictures to understand what occurs:
https://hosting.photobucket.com/imag...MG_4139_1_.JPG Below shows the glaze: https://hosting.photobucket.com/imag...g_seating4.jpg And an illustration of proper ring seating and improper: https://hosting.photobucket.com/imag...g_seating2.png So in order to accomplish this you need to properly load the rings during both acceleration and deceleration to evenly load them. This is hit or miss if driven easily. In fact, these are the actual instructions from GM that the average consumer never see's: https://hosting.photobucket.com/imag..._procedure.jpg And the second thing that just astounds us engine builders is leaving that iron filing and debris filled initial oil in longer than 500 miles. Every mile after that is premature wear shortening engine life. And no, the oil filters on average can only filter out particles larger than 8-12 microns and most of this is smaller so it just keeps circulating and according to the industry studies, 70% plus of internal wear is from abrasive particulate matter smaller than 8 microns. Oil is cheap, why in the World anyone would leave it in is a mystery. The ONLY reason the factory states going that long before the first oil change is just like Ford and every other automaker. Today's car buyer does NOT want to have to schedule a service so soon after getting their new vehicle as it is not convenient. So when one automaker states you can go 1500 miles, the next states 2000! and on and on. Just like hardly anyone opens their hood outside of enthusiasts. Just the same reason they state 87 octane for the V6 and the v8 93....when both have the same 11.5:1 compression ratio. All has been determined by marketing analysis of the demographic they are targeting for a certain vehicle and power choice. The cost conscious wants the smaller engine and everything less expensive. So, in closing, you can do as you please...you paid for the car, no one else, but this you can call any reputable engine builder and verify all. Sound advice. Cheers!! |
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
This is what I saw. https://my.chevrolet.com/content/dam...tion-guide.pdf Doesn't say not to exceed 4K rpm after 500 miles, just to check the oil regularly until 1,500 miles as it might use oil during this period.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 01-13-2022 at 08:38 AM. |
#21 | |
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
MY WAY
What I have done with the 6 New Camaro's is , always warm it up first. Than drive it normally keeping it under 5000 rpms, then change the oil with Mobil one European formula in the correct weight at 2000 miles ,and change the diff and trans fluid at the same time with Redline . Never had a problem in 30 years or had a car that ate oil. When you see what comes out of the trans and diff you will understand . I also have the oil sent out to be analyzed every third oil change , and I never run the oil more than 3500 miles.
Going to do the same thing again when I get my 2022 1LE .
OLD GUY FLYING FAST AND LOW
#23 | |
![]() Drives: 2013 BOSS 302 Join Date: Dec 2021
Somewhere between 500-1500 miles seams about right to me. I think you can go quite a bit longer on the oil change intervals after that though. Say at least 5,000 miles. Just my thoughts, of course changing it sooner does no harm. |
#24 | |
#25 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#26 | |
#27 |
![]() Drives: 2022 Camaro 2SS 1LE M6 Join Date: Jan 2018
Yeah man, the break-in period definitely sucks. I'm currently around 370 miles, so getting close to the 500 mark when I plan to change the oil. Patience is a virtue I guess. This is my second Camaro, so I went through the break-in 4 years ago as well, with the A8. The new one is an M6. Gonna put the skip shift eliminator on hopefully sometime this week. Enjoy your new ride!
#28 |
Modified and dyno'd it at 350 miles.
2020 ZL1LE A10.
