Old 01-09-2022, 06:44 AM   #15
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
@EDFHOBBIES Now that would be AWESOME on an interior piece like a console or door panel......
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350
2019 ZL1 Summit White M6
2018 Hellcat White Knuckle M6
2016 Hellcat GoMango A8
2002 Dodge Viper Viper Red
2002 Corvette Z06 Millennium Yellow
1998 Dodge Viper Viper Silver Metallic
Firecaptain is offline   Reply With Quote
Old 01-09-2022, 06:58 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Originally Posted by SHE'Z 18 View Post
So, how much are you charging to do ours?!? ��. They look awesome!!
350.00 that covers the shipping back, labor, and materials plus you need to send me the mirrors. I would say 2 week turnaround. I have to wait 4 hours for the epoxy to tack before i can lay the carbon, then its 24 hours for the 1st cure. a good 3 to 4 hours to sand each mirror, then i have to reapplying resin 3 more times with 3 to 4 hours of dry time between each coat. Another 24 hours to dry after final coat, then the final sanding takes 3 or 4 hours for each mirror and cutting the excess material off, Clean, prep and applying the UV clear another day.
Old 01-09-2022, 07:25 AM   #17
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
yes.. 100% of my console are replacement parts(pull off the oem part remove oem clips install oem clips on carbon and reattach.) I need to do main section now or I was thinking to paint red since there is all ready red stich and belts.
The console was to complex just like the mirrors to make a replacement part for. here a my interior with red photoshop.
Old 01-09-2022, 07:39 AM   #18
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Looks good!
pauly1119 is offline   Reply With Quote
Old 01-09-2022, 10:10 AM   #19
clg82
Drives: 2020 Camaro ZL1
Subscribed….you’ll be getting a pm soon
Old 01-09-2022, 12:06 PM   #20
Hoov7472
Drives: 2018 Camaro ZL1
The absolute best feature of your work is that I could tell this was real CF right away. The lines in the fiber flow with the contours very nicely. Not like the printed stuff that is all straight and square to the part. Nice work!
Hoov7472 is offline   Reply With Quote
Old 01-11-2022, 12:07 PM   #21
AZ_ZL1
Drives: 2022 Camaro ZL1
Well done EDF it looks great!
AZ_ZL1 is offline   Reply With Quote
Old 01-11-2022, 03:13 PM   #22
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Thank you I just bought some more material and supplies. I'm gonna pull off my mirrors and make another set.
Old 01-11-2022, 09:38 PM   #23
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Keep up the great work and keep the pics coming!!! Are ya gonna do your shark fin as well?
SHE'Z 18 is offline   Reply With Quote
Old 01-11-2022, 10:14 PM   #24
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
You want a extra set of ZL1 mirrors to have at the ready?
I need that hood insert you made to clean up my hole cut out.
Anyways awesome product Jack.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 01-12-2022, 04:18 AM   #25
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'm going to make the insert this weekend just try a wet lay up. If all goes well I invest into a expensive vacuum machine.
Old 01-12-2022, 07:00 AM   #26
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
That came out great, very good job laying the fabric down straight on the contours!
I've had good luck with carbon, contours and Gorillia spray adhesive and it staying laid down.
Before you invest in a good vacuum setup, if you have a food vacuum sealer you should definitely give that a shot first since it's free/cheap. Should be about the right size to skin a mirror too. I have tried using a pneumatic vacuum, vacuum sealer and just gravity to skin carbon. I find the vacuum sealer works about as good as the pneumatic vacuum, even better it seals the bag and easier to use. No doubt a real vacuum setup is the way to go and I eventually plan to, but it's truly hard to beat the food vacuum sealer
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 01-12-2022, 09:26 AM   #27
Phil zl1
Drives: 2022 zl1
Those mirrors look really great. Really nice job.
Phil zl1 is offline   Reply With Quote
Old 01-12-2022, 07:08 PM   #28
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Got 1 installed today.. The time just flies by it seems when you near 50. I can't seem to get all what I need to get done in a day even waking up at 415am and going to bed at 9. Anyhow here is on installed..
