Old 01-08-2022, 11:06 PM   #15
Bob RS
Drives: 2019 Camaro RS 1LT
I have been using the AA Wireless Android Auto for nearly 7 months with absolutely no problems what so ever. This thing connects in under 10 seconds ever time with no issues it is a plus not having to use the usb-c cord which cause nothing but problems when connected to Android Auto. Going Wireless is great phone calls, texting, using Google maps it works perfectly.
Bob RS is offline   Reply With Quote
Old 01-09-2022, 07:34 PM   #16
ember1205
Hot Camaro
ember1205's Avatar
Are you referring to having your phone connected directly by hardware, and it has a USB-C connector on it? That's the setup I've been running since I got the car new almost two years ago and have never had a single issue that traced back to anything other than bugs in Android Auto itself or a need to update the software on the car.
Old 01-10-2022, 11:19 AM   #17
Bob RS
This little device works only with Android phones and makes your phone completely wireless which means you no longer need to connect your phone with a usb-c cable to Android auto. Reason why I went and this direction is because of all the problems when using the usb-c cable to Android auto since going wireless never had anymore problems.
Old 01-10-2022, 11:21 AM   #18
ember1205
Hot Camaro
ember1205's Avatar
If you've experienced issues with a hard-wired connection, it's either a bad cable or there's a problem with the USB port on the phone. My three year old Pixel 3XL never had an issue as long as I was using a proper cable.
Old 01-10-2022, 12:39 PM   #19
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Yeah, good quality cable, no issues w hard wired.
ing for grip.
http://www.motorsportsne.com/
Old 01-10-2022, 03:42 PM   #20
crosive
Drives: 18 zl1
Originally Posted by wintertopdown View Post
Keep in mind, it does drain the battery of the device. My Motorola Razr 5G fits perfectly in the armrest compartment, however while running android auto (plugged in), it burns up.
yeah but now I can plug it into a proper charger that will at least charge the phone by time I get where I'm going
crosive is offline   Reply With Quote
Old 01-10-2022, 10:13 PM   #21
Bob RS
I've tried different usb-c cables and nothing helped or work. When Samsung released the s21 series especially the s21 ultra which I have had issues when using the usb-c cable. Things like unable to voice to text, have text messages read back, and have no volume to low volume to listen to music. After numerous phone calls to t mobile, Samsung it turns out that Android 11 at the time was causing the problem because Android Auto wasn't keeping up with there updates which at the time Android Auto was at 6.4. I believe Android Auto is now getting ready to push out another update from 7.1 to 7.2 because others are still having problems. What makes it strange Samsung tells me it's only effecting a small group.
Old 01-10-2022, 11:10 PM   #22
crosive
Drives: 18 zl1
I had issues with my 21 ultra at first, but once it updated to android 12, the only issue I have is slower than usual charging.
Old 01-10-2022, 11:21 PM   #23
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
https://slickdeals.net/f/15542248-ca...src=SiteSearch
This one's under $60, although I've never heard the name of the manufacturer. Oh and I don't know the country of origin since I figure most everything has foreign parts in it, like all GM products.
TXCSSU is offline   Reply With Quote
Old 01-11-2022, 06:42 AM   #24
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
I don't want to derail this thread, but with this whole wireless AA unit... Is there a replacement charging pad for the older '16's that fits these bigger phones? The wireless AA is great, but it would be nice to be able to sit your phone on the charging pad, but my Galaxy S21 is to big for it.
jamala00 is offline   Reply With Quote
Old 01-11-2022, 08:56 AM   #25
ember1205
Hot Camaro
ember1205's Avatar
It's for Apple CarPlay, not Android Auto.
Old 01-11-2022, 08:58 AM   #26
ember1205
Hot Camaro
ember1205's Avatar
Would you also need something that can provide a higher charge wattage, too? The newer, larger phones tend to not do so well on the older charge pads because the phone consumes power as fast as it's being supplied when you have an app running.
Old 01-11-2022, 08:59 AM   #27
No, there isn't. I did these short edge cuts on mine, and the S10/S10e fit, not sure about that baking pan S21
This is pretty much the best you can do unless you are willing to completely butcher up the backside of the center console.
Old 01-11-2022, 09:09 AM   #28
ember1205
Hot Camaro
ember1205's Avatar
Is that a 1/4 sheet or half sheet?
