#15 |
![]() Drives: 2021 Camaro ZL1, 1970 BOSS 302 Join Date: Dec 2020
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
How long ago did you all get the EOS wing?
I tried it this summer the fitment was not good. The center post had about a 1in gap between the trunk and the post itself. They tried sending me another set of posts and that didn't work either but the gap got smaller. I am about to get the C7 Carbon wing in the next WK or so. Hopefully that goes well.. Sent from my moto g(7) power using Tapatalk
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
I finally painted it a HAMMERTONE satin black recently which is easily repairable when scratched. It is flexible enough to have some GIVE to it and then spring back to normal shape again. I added 6-8 more screws to it along with the stock mounting fasteners.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#18 |
![]() Drives: On Hiatus Join Date: Apr 2020
That looks perfect with the front dive planes. No need for a 1LE with poor DD suspension when you can spend under $1k and get the same look.
#19 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
Granted permission.
#20 |
![]() Drives: 2022 Camaro ZL1 Join Date: Dec 2021
That the exact look I was going for. You have good taste my friend....LOL
2022 ZL1 White
2005 Ford F150 2015 Toyota Highlander 2009 Toyota Highlander 2003 Mustang Cobra 1998 Z28 Convertible 1991 Toyota Camry |
#21 |
Drives: Faster than yours Join Date: Nov 2021
I can't speak for the EOS wing, but I've tried EOS parts on a C7 in the past. Their quality is pure dogshit. Their idea of carbon fiber is absolutely laughable. The real 1LE wing is a work of art built up of layered carbon fiber. The EOS will most likely be a hollow shell of mostly fiberglass/cheap plastic with a cheap carbon fiber overlay.
Go for the ACS Composites 1LE wing if you want aftermarket. |
#22 | |
Hopefully my C7 Carbon wing is ready this or next week. Sent from my moto g(7) power using Tapatalk
#23 | |
![]() Drives: '18 2SSM6 Camaro ‘01C5Z06 Vet Join Date: May 2019
#24 | |
I KNEW however that I DID NOT want the ZL1 wing in a carbon finish anyway because I wanted the wing to blend in with the gloss black finish of the car and the EOS wing certainly does that although as mentioned before their CARBON FLASH is really mislabeled because essentially it is a GLOSS BLACK and NOT Mosaic Black.
#25 | |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
You can always look for wrecked ZL1's at the local junkyard and....
#26 | |
![]() Drives: 98 Z28 SS, 2018 ZL1 HYPER BLUE Join Date: Aug 2008
Thanks |
#27 |
Nightfall Gray ZL1
Drives: 2018 ZL1, 1992 Celica AllTrac Turbo Join Date: Dec 2019
I just wanted to report I was able to find an Anderson Composites wing through Auto Addict USA. They seem to have a great relationship with Anderson Composites and actually have them in stock. The folks there were up front that the one piece spoiler will likely require some massaging (increasing the outer mount holes diameter) to properly fit them but assured me reinstalling the stock spoiler would hide the work. That is good enough for me.
#28 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
