#15 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The pad mu of the copper frees probably has gone down along with the pad's heat capacity, so everything was increased in size to help with both of those criteria.
"KEEP THE FAITH"-Fbodfather |
#17 | |
#18 | |
376 cubic inches of fun
#19 |
![]() Drives: Camaro Super Sport, Six on the Stik Join Date: Jul 2021
All SS's Come with Brembos. The SS 1LE comes with an upgrade in additional pistons.
#20 | |
As long as the ABS cals stay happy! But, maybe we are putting the cart ahead of the horse. The new copper free system may be pretty damn awesome right from GM.
#21 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
However, there is only one size for BCD brakes. That size is made to handle track use on the ZL1 and ZL1 1LE. That means if you get this package on any lower trim it's an upgrade in terms of performance. I'd also bet that pads with copper in them will eventually be made to fit these calipers which would also be an upgrade.
2017 SS 1LE.
#22 |
Nope, they're the same 4 piston as the rear of the SS 1LE.
2017 SS 1LE.
#23 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
The OEM 394mm J57 CCB front pads have same pad material outline dimensions as the new 400mm Blackwing pads. The Blackwing CCB pad material is thinner by about 1.5mm due to the new 38mm rotor width vs. 36mm and an added on NVH shim. I’ll post up once I get ahold of a pad for the 398mm steel rotors. Last edited by RUQWIKR; 12-11-2021 at 07:53 AM. |
#24 |
Just FYI - the larger front caliper we are talking is going to have clearance issues with the common aftermarket 18” rims we run. I only have 3.5mm clearance to the drop barrel on my Apex 18x11 +7 SM-10. The larger caliper is 3.5-4mm bigger radially.
#25 | |
2017 SS 1LE.
#26 |
![]() Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
What's the replacement cost on a set of copper pads and rotors, and how much extra do they weigh?
Nigel |
#27 |
The front BCD / J6H rotor 398mm is 36.6# vs 32.4# on the 390mm J6H. The front pads have the very sticky adhesive to hold the pads NVH backing shim to the pistons making it a bit of a PITA to get the front pads out - like on C8’s (at least the Z51 I’ve worked on of a friend). It has substantial pad area cut away for NVH. If you stick a regular J6H stock or aftermarket pad, you end up with around 1mm of cold ring inboard & outboard not touched by the pad.
On the rears, the BCD / J6H pads use a bonded shim plus the added stainless shim just like a stock J6H pad but has pad area cut back for NVH. It also has, like all the front J6H’s (and J57’s), a wear sensor notch (not used on Gen 6 Camaros). The calibrations were all developed around the stock copper free pads in the configurations they came in. Not sure what, if any, issues would arise by changing pad compounds to stock regular J6H HP1000’s or aftermarket. Just posting the info and pics up as FYI. |
#28 |
![]() Drives: ‘23 SS 1LE Join Date: Nov 2021
Thanks RUQWIKR, that’s awesome info.
Now what will be really interesting is if you can swap in the CT5V carbon ceramics. As far as i know the calipers are the same.
2023 2SS 1LE “Red Hot”
Built 7/14/22 Delivered 8/27/22! |
