#15 | |
![]() Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
I have added an additional fraction of a quart to bring it solidly to half after running it and re checking. I know the dip sticks can be different and the tube could be set differently into the block. Either way I cant see 1/2 quart either way making a difference. Only 3500 miles and I havnt consumed any oil at all. I thought it might use a bit during break in.
#16 |
ZL1 Nut
Drives: 10 SS/RS;12 ZL1;17ZL1;22ZL1;24ZL1 Join Date: Sep 2009
5W-30 or OW-40
I own a 2017 ZL1 and just purchase a 2022 ZL1 and see where they have change the oil to OW-40. Do I need to put OW-40 in my 17
#17 |
Thank you Al Oppenheiser!
#18 |
ZL1 Nut
#19 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Actually, if you are not tracking your SS 1LE, 5W-30 Dexos1 is fine. If you track and DD, and you want to follow the manual's recommendation on the oil, then Mobil1 0W-40 ESP is pretty much your only choice in North America. Thankfully, you can get them for a good deal over at Rock Auto. They go for US$7-ish per quart before shipping, and RA shipping generally isn't too bad IMO. Motul also has a type of engine oil that's in 5W-40 and meets Dexos2, so that could be another option if you don't drive your car in the cold.
Regarding oil capacity, if you are doing your own oil change, I would personally dump in the first 8 to 9 quarts, and then slow down and check the dipstick to see how much you actually need. When I did mine, I needed 10.5 quarts to get it to full. YMMV, and usually I just fill any car I own with a quart less than the recommendation before checking the dipstick to see if I actually still need more. As for when to change the oil, I concur that you should just follow OLM. 3k miles is pretty obsolete nowadays unless you run conventional/mineral-based oil or you track the car like crazy. Any good synthetic oil will last more than 3k miles. I usually just toss those stickers right away if I get them after service. I changed my rear end oil at 500 miles once, and then I think 2000 miles. I use Motul Gear 300 LS, and I have no issues with it, but some people seem to prefer sticking with the OEM AC Delco stuff. The latter will be the safest choice, though again, Motul hasn't caused any issues. Just make sure you do get the LS variant if you do want to try it; there is a non-LS variant that's yellow/clear. LS variant is green.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#20 | |
Ya mon. Here's the latest report if you want to see for yourself. You can see when I changed to 0w40 ESP Formula in the Boron numbers. Before that I used 5w30 Mobil1, Valvoline and Supertech without issue. You can see Blackstone's comments about it in the previous tests results I posted in the same thread: no concerns either way. But when Chevy changed their recommended oil fill, so did I. I live where it stays warm year round so I'm not concerned about the slightly higher viscosity. And the data show that it hasn't done the car harm. None of the oils did TBH. I don't care about the extra $50 once per year and would rather go with Chevy's engineering recommendation over what I can pull out of my ass. Besides, I got a new oil fill cap out of it: https://www.amazon.com/ACDelco-FC265.../dp/B0792NR4C6
#21 |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
"Mobil1 0W-40 ESP is pretty much your only choice in North America. Thankfully, you can get them for a good deal over at Rock Auto."
Hey guys, been asked before, but these days the times are a changing: If you are using Mobil 1 0-40 ESP, where are you finding it? I just had to order from Amazon....Just curious where you're finding it these days... |
#22 | |
I think the main argument for the 0w-40 is protection for BOTH street and track use. For my purposes I'm sticking with the much cheaper Valvoline 5w-30 (dexos 2) which amazon delivers to my door at a better price than wal-mart. |
