Old 12-23-2021, 02:20 PM   #15
Slowhawk
Drives: 1999 Trans Am
I do know if you add the DSX low side pump kit, the lt4 injectors/pump and dual meth can support 800rwhp on a LT1. So 700rwhp with no E is very easy to do on your setup.
Slowhawk is offline   Reply With Quote
Old 12-23-2021, 04:11 PM   #16
s346k
s346k's Avatar
Drives: like an old lady
so what would a setup like this make on 93 alone? 600?
Old 12-24-2021, 08:29 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
There about...will be octane limited on 93 to go above that with a stock compression LT1. The 2650 is a waste at that power level anyway imo. It is "peaky" until you start spinning them 15+ psi. It would be similar to putting a F1a94 on a SLB LT1 and only running 9psi. It's likely not even going to start making any power till 5500 rpm.
Old 12-24-2021, 02:27 PM   #18
asthmamax11
asthmamax11's Avatar
Won't he run more consistent on E40 because of lower temps ?
Peak #'s will be lower but dyno #'s don't win races
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 12-24-2021, 04:36 PM   #19
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Not enough of a power difference between the 93/meth number and E40 number to really say which is faster. Now what’s better for the stock LT1 short block, that’s a different story! E40 on 9 psi is infinitely better to run in that scenario than the 93/meth on 11 psi. Less boost and a cooler combustion chamber to boot will be much better in terms of that short block holding up long term.
Old 12-24-2021, 05:18 PM   #20
KingLT1
KingLT1's Avatar
^facts!
Old 12-24-2021, 06:10 PM   #21
Joshinator99
Moderator
^facts!
Old 12-24-2021, 10:55 PM   #22
asthmamax11
Awesome
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
