#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Ugh. His 'inside sources' are getting worse and worse...
Take 10 seconds to look at the LT2. It's a dry sump. It breathes 'backwards'. Would not be a quick drop in. It also uses the Group B ECU, and no way is that coming to the Camaro. And Camaro is hardly the only vehicle that uses the LT1. It's in the Silverado, the vans, etc.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#16 |
Drives: My wife nuts... Join Date: Sep 2011
C7 never had the LT2
perhaps the op hit the wrong key post #15 is spot on, no way its going down |
#17 |
![]() Drives: Rapid Blue 2022 Camaro 1SS Join Date: Sep 2021
Call it what you will. Hype machine. Click bait. Space filler. These kinds of videos he does are low effort affairs that keep the channel relevant between the usual videos. SEMA just happened last week. If GM were serious about any of this they would have announced something then, or at least dropped some hints about it over the course of that weekend.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000 11/4/2021 - 3100 Status TPW 11/15 11/9/2021 - 3400 Status TPW 11/15 11/24/2021 - 3800 Status built 11/21/2021 12/2/2021 - 5000 Status 12/13/2021 - 6000 Status |
#18 | |
![]() Drives: 2019 Camaro SS Join Date: Nov 2020
#19 |
![]() Drives: Satin Steel Camaro 2SS M6 (ordered) Join Date: Sep 2021
Having done some research on the LT2, it is totally unfit for a front engine layout without major modification.
LT2 is significantly taller from the intake and up, which is fine in the C8, but they would have to use a raised hood to allow the engine to fit the bay properly in a 6th gen. The intake manifold is completely reversed. The ignition coils are also located below the exhaust manifolds rather than on top like the LT1, which means the headers are located high above the valve covers which wouldn’t fit whatsoever in a 6th gen. Not to mention that the LT2 was designed to be paired with the 8 speed DCT, not the TR6060 or the 10 speed. It’s not as simple as just bolting the 2 together, there’s some major tuning that would have to take place on the backend. The LT2 was literally built around a mid engine layout, if they do this they’ll need to completely redesign a large portion of the external components of engine. Just doesn’t make much sense considering it’ll only be used for 2 model years before inevitably killing off the car for good. Only way I can see this taking place is if they had planned this from the inception of the LT2 and have already done all of the R&D in the background over the past few years, this is most certainly not a simple engine swap. Last edited by James Froese; 11-11-2021 at 02:47 AM. |
#20 |
GM Employee
Drives: 2022 LT1 w/ RS+Tech Join Date: Sep 2021
All good points, but it has been said in a GMA article that the final year of the Camaro6 will have a "farewell" package, so never know what they have up their sleeve.
![]() I feel @BundiMan probably has the best inside information as his neighbor works at the plant. I'm assuming some machines would have to be reprogrammed on the line for a fit like this.
2022 LT1 Summit White - A10
RS | Technology | Satin Black Appearance | Sunroof | Dual Mode | Carbon Flash Wheels | Illuminated Sill Plates | White Door Trim 09/01/2021: 1100 | 09/24/2021: 2000 09/29/2021: 3000 | 10/05/2021: 3100 | 10/11/2021: 3400 | 10/26/2021: 3800 (TPW 10/25/2021) JCT - Picked and Paired: 11/04/2021 | Dispatched: 11/05/2021 | Delivered: 11/08/2021 |
#21 | |
![]() Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
#22 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Doubt it will happen. EPA certs are needed, new parts for the Camaro vs. the 'vette, and the trucks are using the LT1 blocks, etc.
Why would gm (not GM) dump that much effort into a platform they are going to kill?
#23 | |
![]() Drives: C8 Corvette Join Date: Mar 2013
GM would have to invest multiple millions here to bring a high modified LT2 version to the already outdated alpha-1 platform for just a year or two? It just isn't trustworthy at all.
#24 |
![]() Drives: 2018 Camaro SS Join Date: Jan 2021
I’d buy it….. would give me reason to not look at new mustang…
Sent from my iPhone using Tapatalk |
#25 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
For GM to put an LT2 in the Camaro, you need to change the sump, the intake manifold, and the exhaust manifolds and hey, look, you are back to having an LT1 engine. |
#26 |
![]() Drives: 2022 SS 1LE Join Date: Dec 2020
(X) Doubt
Alpha Platform Aficionado
2022 Camaro SS 1LE | Rapid Blue | Manual Cadillac ATS 3.6 RWD | Daily Driver Previous: Challenger Scat Pack Widebody |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
No, LT1 engine will stay.
LT2 enine is essntially the sam with Hi ram intake, headers and Dry sump.
2012 Yukon XL Denali w/ 6.2 AWD |
#28 |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
Hopefully they phase out the entire car, it's in dire need of a redesign/update and sales reflect that. Would love to see a good looking car with a 480+ hp base v8 and a 700+ hp flagship
