Old 11-22-2022, 03:44 PM   #15
Z OH 6
Drives: 2024 CT5-V Blackwing
Originally Posted by Camaro1973 View Post
No why would hot air end up in the cabin? The chiller sits behind the front bumper.
I think he means some of the AC efficiency is lost because the AC now has to cool the blower too. It is normal for the AC to take a small hit in performance. It should not be blowing hot air though.
Old 11-22-2022, 03:58 PM   #16
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Originally Posted by Katech_Mike View Post
I believe that he may be referencing the air conditioning not working as well with an interchiller installed(small language barrier possibly).
Which in my experience while not a huge difference when it's really hot and humid out it does impact the performance of the AC in the car.
I think he means some of the AC efficiency is lost because the AC now has to cool the iblower too. It is normal for the AC to take a small hit in performance. It should not be blowing hot air though.
No no, it is not a language problem...asked 3 tuners here in EU and all told me a chiller will make hot air to enter in to the cabin. Do not know why and no reasons where given, but as I suppose the air will be inside the SC circuit (if I understood how it works).
A/C will be a bit degradated working at 50% and unused in the cabin w/ the 100% in the HX, I know that
That's why I asked here, to confirm my thoughts or no.
Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 11-22-2022, 06:28 PM   #17
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Thank you.
AC is only slightly degraded because the refrigerant is passing through not only cabin lines but also the chiller, but it’s very minimal especially on the FI interchiller.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 11-22-2022, 09:38 PM   #18
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
I have one sitting for my C7Z but have hesitated putting it on now because some tuners on Facebook saying it doesn’t work as well as advertised. It has to make a substantial difference in 70+ degree temps.
CamOnlyJabroni is offline   Reply With Quote
Old 11-22-2022, 09:55 PM   #19
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
My MAT's hover around ambient and very rarely hit 100F. (even in summer)
Works very well... The coolant stays around 38-45F.
Old 11-23-2022, 04:07 AM   #20
Z OH 6
They work extremely well, it really is equivalent to having a permanent ice tank.
Old 11-23-2022, 06:56 AM   #21
Akura
Akura's Avatar
Thank you all for your inputs!
Old 11-23-2022, 07:35 AM   #22
CamOnlyJabroni
Good Deal. I’m going to get AN conversion fittings and get rid of my floppy rubber hose that came with the maggy kit at the same time.
Old 11-23-2022, 07:40 AM   #23
Z OH 6
The ONLY downside to a chiller is that they're a bit time consuming to install. Otherwise, I don't know of any negatives if installed properly.
Old 11-23-2022, 10:05 AM   #24
Katech_Mike
Drives: 2015 Camaro ZL1
Thank you.
There is no way for hot air to enter the cabin with the chiller. It is mounted near the front core support. No where near the cabin.
Katech_Mike is offline   Reply With Quote
Old 11-23-2022, 10:07 AM   #25
Katech_Mike
They work well in our testing.
There are still some gains to be had using a chiller in conjunction with an ice tank and EMP pump.
Old 11-23-2022, 12:13 PM   #26
CamOnlyJabroni
How do you have your fans setup? I was thinking about trying to only have them come on like they would with coolant temp. That way they aren’t blasting all the time. To that’s the only downside I can think of
Old 11-23-2022, 12:17 PM   #27
CamOnlyJabroni
Thanks for the input. I have an upgraded pump already. I’m definitely going to put it on now.
Old 06-08-2023, 06:21 AM   #28
manders500
Drives: 2017 ZL1 Camaro
I know that this is old but I am curious how you wired the EMP pump? Did you use anything from the stock pump wiring?
manders500 is offline   Reply With Quote
