Old 12-15-2021, 01:55 PM   #15
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
now available from corsa
https://www.corsaperformance.com/col...KU2NuD8.Qam35u
TLSTWIN is offline   Reply With Quote
Old 12-15-2021, 02:32 PM   #16
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Originally Posted by WhiteMale View Post
Whats the expected MSRP?
$599.99 - $609.99
Old 12-15-2021, 03:37 PM   #17
clg82
Drives: 2020 Camaro ZL1
20HP and 30LB FT TQ?!? Umm ok......lol
Old 12-15-2021, 03:49 PM   #18
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
It comes with a small no’s bottle attached to the intake
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 12-15-2021, 03:51 PM   #19
Dave777
Drives: 1985 Z28
RPM did a dyno test with stock air box, Rotofab no tune and Rotofab with tune.
Corsa should be very similar.
https://youtu.be/7-bRgzzeZfQ
Dave777 is offline   Reply With Quote
Old 12-15-2021, 04:04 PM   #20
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
100% true. my car and at the dyno I worked part time at. you feel the difference for sure.
We pulled multiple baselines, swapped out the intake on the dyno, did mutlipe more pulls. No tune due to the car still being under warranty. They tried MULTIPLE styles before doing this one on my car. It is no smoke and mirrors.
my car is the one in the picture and their test mule.
Old 12-15-2021, 05:21 PM   #21
Domo14SS
Domo14SS's Avatar
Drives: 2019 Camaro ZL1 1LE
Have any sound clips of it that you can share? I'm definitely interested!
Domo14SS is offline   Reply With Quote
Old 12-15-2021, 05:35 PM   #22
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
It's hard to hear the SC wine in the video due to it being inside. But I will try and capture it in stealth mode
Old 12-15-2021, 05:44 PM   #23
clg82
How different is the design compared to any other of the CAI available on the market currently? Those have been shown to show negligible gains. Real question here not trying to be a smart ass.
Old 12-15-2021, 06:07 PM   #24
ZL1plumbin
Drives: ZL1 1LE on order
I thought the consensus is that any CAI on an untuned car will eventually adjust back to “stock” timing/fuel after it learns the new parameters? Some guys were saying after so many miles or months….
ZL1plumbin is offline   Reply With Quote
Old 12-15-2021, 06:25 PM   #25
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I wish people would dyno these: a) after 20 mins of road driving for the computer to "learn" the new box, and b) with the hood down since that is how the car actually operates.
If it's only an hour or so later, even with a 20 min drive, the conditions should still be pretty similar but at least we would know if the computer "relearns" and compensates backwards even with the additional airflow (as is rumored).
Also, with the hood up the air filter is free to pull air from the less restrictive surrounding open atmosphere. With the hood down it has to pull from a more restrictive intake tract.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 12-15-2021, 08:00 PM   #26
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
well, the car was dyno'd for over an hour, the car does relearn and immediate starts pulling and adding timing almost immediate.
not only do they try different styles, some which actually lost 50hp, they also test other manufactures intakes on my car at the same time.
They can't be dyno'd with the hood down because you can't create enough airflow to keep the car cool like it would be on the road, so it actually would be getting MORE air on the road with the hood down not less. The car is designed to flow air through the car and to the intake area. The intakes actually produce more power on the road due to the volume of air flowing to and through the car.
Old 12-15-2021, 08:06 PM   #27
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
It doesn't take days, miles, months, etc for the computer to adjust.
The car immediately started to advance and pulling timing as soon as we tried different styles and boxes. One even threw a SEL. it adjust for safety (AF), but not power.
The car still has the same power increase as it did when we tested it. I was going to have a dyno before the winter weather hit, but they took my car again and installed the double "X" pipe cat back system on it and didn't have time to get to the shop. wont be back out there until spring now.
Old 12-15-2021, 09:14 PM   #28
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
I am not going to compare, degrade, any other manufacturer's product. What I can tell you is corsa tried several different tube sizes and shapes and choose this one.
they also due a ton of airflow testing through all of their products. intakes and exhausts. obviously the better and smoother the air flows the more power it will produce.
I actually was going to go with the AFE intake before they approached me to use my car. They were testing new truck intakes at the shop when they saw my car. Once I saw, heard, and felt the intake on the car, I was very pleased.
