Old 10-14-2021, 10:08 AM   #15
D3adch1ld
Drives: 2019 Camaro ZL1 1LE
Originally Posted by Spaceme1117 View Post
So to use this metal thermostat housing, you need to use an LS thermostat?
Probably going to order this and just want to make sure I get everything that I need for it.
Correct, the aluminum housing requires the "traditional" shaped thermostat. The LT engines have a multi piece unit that only works with the plastic housing as it has brackets and such inside.
Sent from my SM-F926U1 using Tapatalk
D3adch1ld is offline   Reply With Quote
Old 10-14-2021, 10:40 AM   #16
74z/28
Drives: Looking
Does anyone have the part # for the correct temp LS thermostat to use? I would like to have a set handy also. Thanks!
74z/28 is offline   Reply With Quote
Old 10-14-2021, 11:06 AM   #17
D3adch1ld
I used this one as I also struggled to get a 180* OE LS t-stat. So far, so good. Time will tell
https://granatellimotorsports.com/i-...es-53080s.html
Old 10-15-2021, 06:36 AM   #18
74z/28
Drives: Looking
Thanks! I will order a set for another winter project.
Old 10-15-2021, 06:54 AM   #19
Smokin19
Drives: 19' ZL1 A10, w/pdr
According to the AMP website it comes with a 160* stat.
Smokin19 is offline   Reply With Quote
Old 10-15-2021, 07:19 AM   #20
D3adch1ld
AMP does, but they seem to use a low quality unit. Their disclaimer for the thermostat doesnt put me at ease.
Old 10-15-2021, 11:12 AM   #21
Smokin19
Don't see the disclaimer on the site. Can you post what you saw?
Old 10-15-2021, 11:22 AM   #22
D3adch1ld
I stand corrected! DMS has the disclaimer. AMP offers Motorad which does carry lifetime warranty.
