Old 09-21-2021, 11:48 AM   #15
HD_ZLE
HD_ZLE's Avatar
Drives: 2020 ZLE
Sorry, I didn't mean "you" I meant it as a figure of speech in general. I'm with you, the more the merrier lol
Originally Posted by sr71bb View Post
I dont. I think MORE camber is a GOOD thing. My car handled better with -2.4 rear camber compared to -2.0 rear camber.
2020 ZLE A10
Rotofab, SPL suspension goods, Cobalt XR1 pads, Apex wheels
HD_ZLE is offline   Reply With Quote
Old 09-26-2021, 02:02 AM   #16
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
SET UP update
UPDATE and Results on Set Up
9-25 I went out to MSR to run with the APEX boys CCW on the 1.7. I had INTITIALLY my set up at -3.1 degrees FRONT camber and -2.4 degrees REAR camber with VERY little TOE OUT on both. (Correction: Toe was set and not changed from where the settngs were on the screen I showed the HUNTER alignment machine printout)
I was running MICHELIN slicks 30 68 18 on APEX EC7 ET27 18 x 11 wheels on all four corners,
After the FIRST session, I felt like the car needed MORE front camber so I MAXED that out at -3.6 degrees. The car hooked REALLY well and I had picked up some additional power from some bolt ons I had AMP do and I could feel that at the top end of straights. Traction control setting was left ON and I was in TRACK mode. Car braking was GREAT. Later on I turned traction control OFF and I found I was quicker but unfortunately I did NOT catch that on my LAP TIMER on those particular laps.
I managed a 1.20 lap time in my sessions (see attached file) and I turned the driving over to Adam Poland at DOGHOUSE Performance to get his feel on any suggested set up changes. Adam was SHREDDING the track and was 3-4 seconds FASTER than me and was lapping cars (we were in the red group)
Bottom line is the car is ALMOST there, We are going to swap out the 1LE Sway Bars with something a little beefier because at the VERY limit we were getting a little too much body lean in the corners. I also am going to have AMP finish up the motor mods so that I am in the 550-580 RWHP range. For THIS event they installed a ROTOFAB , an LT2 manifold, 160 degree thermostat, and FLEX fuel sensor so I ran E85 which I burned up at a rate of about a tank and a half (lol) over SIX 20 minute sessions.
SHOUT OUT to Adam Poland at DOGHOUSE PERFORMANCE for taking the time to throw our asses around in my
3700 pound fat pig of a car (LOL) and to AMP (Bryan Pomeroy)..
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-26-2021, 05:21 AM   #17
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
Thanks for sharing - what was the final alignment setting for toe? Toe out is different from where you started (the settings on the first post)? Thanks
Zl1+911 is offline   Reply With Quote
Old 09-26-2021, 06:48 AM   #18
sr71bb
sr71bb's Avatar
Sorry My Bad. We used all the alignment setting identical to my post earlier where I showed a PIC of the HUNTER printout EXECPT that we ran MAXIMUM front camber of -3.6 nstead of -3.1
Retired Cars BELOW:
Old 09-26-2021, 02:33 PM   #19
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I can recommend this setup for sway bars: Hotchkis front and BMR rear. I'm running them
See post # 8 & 9 for links to parts
https://www.camaro6.com/forums/showthread.php?t=563149
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 09-26-2021, 02:42 PM   #20
sr71bb
sr71bb's Avatar
THANKS!! Why did you not run BMR front and rear sway bars instead of hotchkis on the front only???
Retired Cars BELOW:
Old 09-26-2021, 03:46 PM   #21
carguy55
carguy55's Avatar
There are many pages talking about this setup keeping the 1LE handling balance and the fact that BMR front bushings are crap. Watch my last 3 video on my Youtube and you can see how the bars worked at COTA, both set on the middle.
(over SS 1LE)
Hotchkiss
Adjustable: F 40%/65%/90%, R 25%/35%/50%
BMR
Adjustable: F 6%/34%/69%, R 46%/70%/98%
Non-Adjustable: F 41%, R 16%
https://www.camaro6.com/forums/showthread.php?t=559810
