Old 09-11-2021, 04:30 PM   #15
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I wouldn't say it is extending anything, just preventing leaks via damage during install with new seals.
I know my replacement injector set went in like butter when replaced after using that tool and I have no regrets or concerns. The tool definitely shaped and compressed them properly, per the service manual prior to install. If something went south with a seal and I had to pull my blower off again and replace both the hardlines again I would have wished I saw this thread. The hardlines alone cost 3x that tool let alone 2-3 hours each way to R/R the blower.
Mine were replaced once using the method you are suggesting and I had either a leaking seal or bad injector in cylinder #3. I'm was not taking the chance for 45 bucks.
Old 09-12-2021, 05:45 PM   #16
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
As far as I know, it isn't used for boosting voltage so much as preventing voltage drop at high loads, which helps preserve a healthy safety margin. Whether or not it's "critical", I am not able to tell, but (as per Ted Jannetty's advice) my car has one to make sure it's on the safe side of fueling.
Yep, I can see the R-WHP in your sig and understand the requirement. Clear. In my case though, I am planning no more than stock ZL1 R-WHP levels which should be just about ~ 560-560 WHP @ 93 Pump gas?
Old 09-12-2021, 06:02 PM   #17
Eldi Z
Depends on your desired power level IMO. If you're going for low to mid 600s WHP then you can generally tune the FSCM with the LT4 in tank pump and be fine. If you want more you definitely want the JMS.
Plans are a modest 550-560 RWHP @ 93 Pump gas. Not adding Meth nor Ethanol to the mix - so I guess advancing Ign. timing too much is not an option, so more "safe" WHP than that will probably not be happening anyway.
The setups that I am considering:
1.) Centri: Procharger's "CARB Compliant" kit (the one that retains the stock upper part of the airbox), P1X (instead of the 1SC) + Stg.2 FMIC. Boost level with these kits is set at ~ 7 PSI as far as I am aware?
Or
2.) PD: Stock GM material - TVS2300 / ZL1/Z06/CTS-V style + ADM /Weapon-X, Etc. "installation kit" (mostly stock GM ZL1 parts + adapter plates / various other fasteners, relocation harnesses, etc.)
Main concern with PC's Centri option is, that it shares the 6-PK accessories drive belt (I.E. with the alternator, AC, Etc.) - I am not sure about the reliability and sturdiness of such a system But maybe, with only 7 # of boost it will hold up OK?
Old 09-12-2021, 06:10 PM   #18
Eldi Z
Originally Posted by LiqTenExp View Post
Make sure to get an injector seal tool to pre-size them before insertion! Something like this: https://www.amazon.com/gp/product/B088TLZBRT The part labeled 245-4 in the picture is really all you need for new injectors.
Check here for pipe part #s: https://www.camaro6.com/forums/showp...9&postcount=17 I replaced all of LT4 injectors with a new set this year, one in Cylinder #3 was causing misfires, did the whole set.
Thanks for the Heads-up
I was surely going to replace the hard-pipes, but was not aware of this injector insertion tool How much does this tool cost? The link in AWS reads "no availability"
Old 09-12-2021, 06:15 PM   #19
Eldi Z
[QUOTE=Eldi Z;11069722]
Or
Mistake! meant the Stock TVS1700 (1.7 L) Charger of course....
Old 09-12-2021, 07:15 PM   #20
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
https://www.amazon.com/Injector-Repl...05-18683AA000/
Old 09-12-2021, 07:16 PM   #21
I had the JMS voltage booster already at 560 rwhp, it's relatively cheap insurance and gives peace of mind.
(Plus you know how it goes, once this is done, you'll start wondering after a couple passes at the dragstrip what 700 hp feels like, then 850 hp becomes very interesting all of a sudden... Just look at the specs and horsepower numbers in this very thread LiqTenExp is very modest with his signature, but rest assured that his car is a beast.)
Old 09-13-2021, 05:28 PM   #22
Eldi Z
I got a "page not found" from AWS.
Can you re-check the link?
Old 09-13-2021, 05:35 PM   #23
Eldi Z
I guess that I understand the direction, however (and unfortunately...) where I am stationed right now there are no strips, so I shall have to remain content with the 560-580 RWHP on the streets for a while ;-)
In addition, I understand that the FSCM/CCM is still tunable with a satisfactory effect for this range of boost level (~7-9 PSI) and WHP level...
Old 05-18-2022, 06:15 PM   #24
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I bought the Amazon seal tool listed in this thread, looks cheap/China and reviews are sketchy with folks tearing up seals. So I ordered the OTC kit and will return the $30 Amazon one. $150 but they are prob the OEM supplier. I’ll skimp on some tools but high pressure injector seals doesn’t like like a good one.
What are folks doing to remove/install injector clips? GM tool for that is $193. I think I’d just buy new clips and be careful installing.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 05-21-2022, 12:39 PM   #25
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Or
I have the p1sc1 installed with the factory box setup and stage 2 intercooler and I'm making 565 rwhp on the LT1 fueling with 6.5 lbs of boost. If you go with the P1x setup stage 2 and your upgrading to the LT4 fueling you'll make 600 easy at the full 7lbs boost. After that you will be looking at getting internal to the engine with pistons and cam work that can get you into 700 range .
I chose not to go LT4 but now that I have that in site I may do it at a later time. I'm in no rush that 565 hits different and its a ball to drive as is but from the start 600 was my goal. Only time will tell.
WiggyB is offline   Reply With Quote
Old 05-23-2022, 09:25 PM   #26
Chrome383Z
Chrome383Z's Avatar
Highly recommend this tool. The bore is machined to a smooth finish unlike the Chinese junk I bought on Amazon. 👍
Old 05-24-2022, 06:41 AM   #27
cjperformance
cjperformance's Avatar
If i recall, the new injectors come with new clips. I just carefully used a large flathead screwdriver and needlenose pliers to remove them. No issues. Putting them back on was pretty easy by hand. A couple of soft taps with the screwdriver handle to get them fully aligned and seated.
Also, i did not use a seal compression tool. It's not required, but prob still a good idea.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 01-14-2025, 05:52 PM   #28
bowtie_thunder
Camaro Connoisseur
bowtie_thunder's Avatar
Drives: Red Hot 2020 Chevrolet Camaro 2SS
I hate ressurecting dead threads to zombie levels as much as the next guy, but what did you use to fit new seals on?
I'm currently using my vehicle as a work project. I recently put together an LT4 fuel system and LT2 intake to get literally the same goal WHP as a max effort N/A build, no PD or centrifugal. I also don't have a GM tool to remove the injectors from the rail, but I'm confident I can get it off with your method. I don't plan on swapping injectors often, so I can't really see myself getting a nigh-$200 tool that I'm only going to perhaps use once. Any tips on this?
2018 Camaro SS Vert, A8, Non-MRC Hacked & Stolen; R.I.P.
Current: 2020 2SS Camaro, A10, Non-MRC
PLM Axlebacks | GMPP CAI | GM Flex Fuel Sensor w/Gen 5 DIY Harness | Full LT4 FS | LT5 TB | 530 WHP on E81
bowtie_thunder is offline   Reply With Quote
