Old 09-12-2021, 09:26 PM   #15
rocknss
rocknss's Avatar
Drives: 2017 50th Anniversary Camaro SS
Originally Posted by Dabjbr View Post
I came from a BMW where you could use a Cobb accessport or similar device to flash your ECU back n forth between tunes or factory setup.
Is there anything similar for the Camaro?
If all that is done on a Camaro is E-85 you could flash the ECM with the stock tune. But if there were mods done that require a tune for the car to run then you are out of luck.
Glad I live in WI, here they just plug in the OBDII and read for codes and readiness. I feel sorry for all you CA Camaro drivers!
2017 50th Anniversary Camaro 2SS
2016 Chevy Malibu LT (wife's car)
2004 Chevy Impala (winter car)
2001 Chevy Camaro SS (sold)
1969 Chevy Suburban (restoration project)
rocknss is offline   Reply With Quote
Old 09-23-2021, 12:35 PM   #16
sactownbwoy
Drives: '22 Camaro ZL1 1LE A10
This will be interesting because there are CARB legal superchargers but they require the CARB legal tune from the manufacture. I'm in Cali and this is the route I'm looking at going later down the road, Procharger CARB legal kit.
sactownbwoy is offline   Reply With Quote
Old 10-01-2021, 12:48 AM   #17
Baddawg53
Drives: 17 hyper blue 2SS M6
It's super easy to swap back in the original tune, I use HP tuners, literally just takes a few minutes.
I can't imagine they have a system that's capable of determining that your car used to have an illegal tune in it, but I obviously don't know this to be fact.
Baddawg53 is offline   Reply With Quote
Old 10-01-2021, 01:00 AM   #18
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Can the end user do the swap back n forth or does it require the tuner doing so remotely?
Dabjbr is online now   Reply With Quote
Old 10-03-2021, 12:34 AM   #19
Baddawg53
No remote tune necessary, once you have both tunes saved on your computer, just swap back and forth as much as you want.
Old 10-03-2021, 08:37 AM   #20
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Do you have to start the car when they plug it in? I suppose if you didn’t flip the stock tune in once you park. lol
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
