Old 09-03-2021, 01:14 PM   #15
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Originally Posted by IneedAZ View Post
i usually get the 5gal Boostane when they run the 20 or 25% off with free shipping. I dont have any stations near me that have Race gas. I can get it at a local speed shop though. I think it is more costly than the Boostane though.
I just spoke to the tuner and he was telling me i have plenty of fueling avail still. He was able to maintain 80psi on the low side on WOT. The prev tuner had it falling off during WOT and i was at 6.2inj pulse width and now im at 5.0 inj pulse width.
Sounds good.
What are you using for the low side? DSX aux pump?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 09-03-2021, 01:28 PM   #16
IneedAZ
IneedAZ's Avatar
Originally Posted by swisstyphoon View Post
Sounds good.
I'm using the dsx aux pump along with the Lingenfelter High flow check valve.
Old 09-04-2021, 08:28 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If the injector pulse is at 5.0 then I am sure it will handle E40. That being said I would be curious to know what he did to get the injector pulse width that low? One way is lean the afr out and going from 11.8-12.0 to 13 afr would do it.
I would verify with your wideband what AFR you are seeing because it sounds like tuner leaned it out to drop the IPW's.
Old 09-04-2021, 11:51 AM   #18
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I doubt hes at 5.0 (not at the right AFR). I am at 5.5 and we have pretty much the same build and pullies making the same power and im right around 12 AFR.
He seems to be running lean though from what hes posted, and if really at 13 afr I've never seen anyone tune that lean.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 09-04-2021, 11:56 AM   #19
KingLT1
KingLT1's Avatar
That's what I am saying...I have seen some run ZL1's lean like that before. Only way he would have that low of IPW.
I know with race gas you can run much leaner which will extend the fuel system out much further but pump gas I prefer 11.7-12.0 and 12.0-12.4 max on E. Jmo ymmv...
Old 09-04-2021, 01:28 PM   #20
IneedAZ
IneedAZ's Avatar
Hopefully I will be able to answer some of your questions when I get the flex fuel done. He said he is going to be out if town and for me to check back in the middle of the month. I will definitely update you guys what happens with it. Wonder if he got more out of it cause of the Boostane? I had somewhere between 8 and 16oz in it before heading to his shop 45mins away.
