#15 |
![]() Drives: Chevy Camaro ZL1 Join Date: Apr 2021
The stock pads are Ferodo DS1000s and work really well on the street and road course.
I replaced the fronts with DS2500s, which were a little better on track and still just fine on the street. The probably dust a little bit more, but it's not bad at all. Stick with OE on the rear. |
#16 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Any fluid other than Castrol SRF or Brembo HTC64 can be a problem. The stock pads are an incredible deal, it's amazing that a pad that performs this well on track is also quiet on the street. DS 1.11 are NOT quiet on the street, but amazing on track. They cost 3x the stock pads and last 2x-3x as long. |
#17 |
![]() Drives: 2017 ZL1 Join Date: Aug 2020
I followed AZ1 LE advice and went with the gloc pads and found them to be a better option for me.
Coming from an 800lb lighter car with 150+ less hp the weight of the ZL1 is noticeable, even with the better chassis and getting the beast to whoa after lots of go just takes more effort. |
#18 |
![]() Drives: BMW M3, ZL1 1LE Join Date: Mar 2019
I had no complaints with the stock pads but found true race pads (Cobalt XR1) to be much better in terms of modulation, release and pad life. I didnt find a difference in rotor temps which I was initially worried about.
#19 | |
That's good information, I was worried I might cook my caliper paint using DS 1.11 pads but after 9 track days the paint shows no signs of heat discoloration. |
