Old 08-31-2021, 04:17 PM   #15
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by IneedAZ View Post
how much diff u think there is from my wideband to his sensor back at the muffler? Would u think his would show a little leaner?
If you have cats, it’s going to read leaner out the tailpipe. Which is why most tuners put a bung in header or use the front o2 sensors.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-31-2021, 04:17 PM   #16
IneedAZ
IneedAZ's Avatar
i just looked and my Stoich is stock setting which is 14.10840. My PE is 1.150. Based off those settings it is commanding 12.27, correct? I guess if this is correct, i just need to do a quick wot log and see what i am actually getting and adjust the MAF if needed.
Old 08-31-2021, 07:15 PM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes log MAF vs EQ error in histogram.
