#15 |
Petro-sexual
I found a channel, from a Member here I believe, on YT and noticed they track what looks like a Callaway ZLE. At any rate, the car is not stock, but I noticed they did some trimming on the panel that holds the extractor itself. I think that's along the lines of what I'm thinking about doing. I'm not worried about water or anything, so maybe I'll just take the plunge and do it. lol.
#16 |
![]() Drives: 2012 BMW 135i Join Date: Nov 2016
Mine is fully opened like the GT4 Camaro. I JB welded two studs to open it up. Can't say its helped or hurt but it is opened up and allows the rad to exit hot air at much larger rate than could have been possible with the OE plastics in place.
#17 |
Petro-sexual
So I priced-out the panel and figured I wouldn’t cry too hard if I hated it. Fortunately- I don’t.
I pretty much trimmed to the edge of the rain catchy-thingy-gutter, along the top. I didn’t want to loose too much strength, so I left as much as I thought would be beneficial and still not look entirely crap. I don’t think I’ll actually see an improvement in any PIDs, but I can feel a little better I might get a little more air flow. I must say the attention to detail GM put into the area is cool. There were seals on the gutter (which I never noticed before) and around this support panel. There is no way I would leave the actual extractor unsupported by this panel though. It was neat to see the actual CF sheets underneath though. Also - for all the sheet I gave Edelbrock for having to cut the hood to clear the 2650 on this car, this wasn’t too bad. There’s definitely some loss of support cutting this panel as much as you need to, but it’s probably not as big a deal for most people.
#18 | |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
#19 | |
Petro-sexual
That's some mean stuff going on in those videos that's so cool to watch. The latest troubleshooting video was super-cool! It kinda' inspired me, too.
#20 | |
Dyno Show Queen LOL
Later I removed the plastic part glued on the back side of the oem carbon insert. Its like a stand of and hold 2 or 3 of the bolts for the metal cover. I then reinstalled the metal cover and layed the template down over it to make the final cuts for the insert. Now I run part of the metal cover and the carbon lpe cover. I love carbon but I can't stand that its 1 x 1 weave prepreg material and its not that glossy. I bought an extra insert and I'm having some made out of 2 x 2 weave carbon and it will be glossy vs there semi gloss also there part has a lot of imperfection. not in the weave but in the resin or epoxy it has some air bubbles or holes. I have never used the rain channel covers ever.
#21 |
Dyno Show Queen LOL
I ended up selling my trufiber part I could not bare to cut it also since the carbon didn't match it would look stupid. I think I'm going to get another one and cut since I'm having the insert made in the proper weave and sheen.
I'll have to cut the carbon cover on these lines..
#22 |
Petro-sexual
Considering you were one of the first I noticed doing that I definitely commend you on bravery AND the foresight in being conservative in your trimming. So far as I can tell, you kept it as tight as necessary and didn’t waste much, if any trimming. Many KUDOS.
