Old 08-12-2021, 01:38 PM   #15
Blu Ray
ALWAYS-N-BOOST
Blu Ray's Avatar
Drives: 2021 ZLE A10
Send a message via AIM to Blu Ray Send a message via Yahoo to Blu Ray
2012 1LS M6 Black-Sold
2013 2LT M6 BluRay- Sold
2015 1SS 1LE M6 Black-Sold
2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10
Blu Ray is offline   Reply With Quote
Old 08-19-2021, 07:01 AM   #16
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Whatever happened here?
Old 08-19-2021, 11:54 AM   #17
dengel223
Drives: 21 ZL1 A10
I didn’t see any more comments since I posted all the logs. I have one friend that thinks it might be belt slip but I don’t see any indication of that on the belt. I’m going to take the car to a tuner for some Dyno pulls to help diagnose the issue. Any other suggestions?
dengel223 is offline   Reply With Quote
Old 08-25-2021, 07:32 PM   #18
dengel223
Drives: 21 ZL1 A10
Hi Res PID
Originally Posted by Megahurtz View Post
You're logging the wrong MAP PID. You have to use the Hi Res Non SAE MAP PID.
I believe Megahurtz is correct! It looks like the built in boost formula may be different across different VCM Scanner versions/downloads. My boost formula uses the regular MAP sensor rather than the correct MAP Hi-Res formula. I read on the forums that some people have the correct MAP Hi-Res sensor in their boost formula. I'm not sure why they are not consistent.
Attached screen pics of my built in boost formula vs the custom one I made.
Old 08-25-2021, 11:33 PM   #19
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
So you feel the extreme power loss at WOT on track, and are able to log it, and the dealer doesn’t care that your nearly new unmodded car is very broken? What is their response?
I would think the car would throw multiple codes if this was happening.
Call GM customer support and go to a different dealer.
SFV1LE is offline   Reply With Quote
Old 12-02-2021, 09:35 PM   #20
714camaro
Drives: Chevy Camaro 2SS
Can i use this config for trying to diagnose a problem on a LT4 supercharged Camaro ss with a8 trans? Just trying to get a data log posted for others to see
714camaro is offline   Reply With Quote
boost, map, psi, zl1
