#15 |
#16 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Has anyone actually tested or quantified that? GM probably uses these same endlinks on vehicles with stiffer swaybars than the SS 1LE, like maybe even some trucks and SUVs. The links are only in tension and compression, and my guess is they are way overengineered for the job.
Matt Miller
2020 SS 1LE |
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
its mostly needed or used when you lower the vehicle also either lowering springs or coilovers
#18 |
![]() Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
The other benefit of aftermarket adjustable end links is the ability to unload the sway bar when the vehicle is at rest. This allows for equal roll resistance in either direction.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#19 |
Both kropscamaro and Scargoes are correct with those points. That said, if your car isn't lowered and/or you can't/won't adjust and zero out corner weight diagonals, then I don't think you need aftermarket end links.
Matt Miller
2020 SS 1LE |
#20 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
The heims also remove any deflection from the stock bushings, how quantifiable that is I'm not sure. Hard to tell for me personally
#21 |
i may have a set of spl parts ones for sale soon if anybody needs a set
the rears did not work with my afe power swaybars and vorshlag sent me some whiteline ones to try with my mcs coilover kit
#22 |
But the stock front endlinks also use ball joints, not rubber bushings.
Matt Miller
2020 SS 1LE |
#23 |
Been a while since I changed them out, for some reason I was thinking one side had bushings. The spl end links are beefier, don't know how much of a difference people will feel but I haven't really noticed any. Will post up a comparison picture when I get home for reference
#24 |
i have 3 sets now lol powergrid ones , spl parts and whiteline ones
#25 | |
Matt Miller
2020 SS 1LE |
#26 |
Yep you nailed it. The rears have one bushing. Second pic are the stock rears.
#27 |
gonna sell my rear spl parts endlinks if anybody brand new in box $175 plus freight
| Tags |
| adjustable endlinks, bmr, endlinks |
