#15 |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Crank that worm clamp down some more. that gap is excessive
#16 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
I'm sorry, I left a very important part out of my post from last night. That was with the clamp loose to show the fitment, all other connections when loose are alot more snug. It has been tight and was tightened after the picture. They're as tight as I feel comfortable doing (which is pretty snug), I'm leery about cranking down too much on them with the carbon flexing I fear it will crack if I do it too much.
I checked and made sure TB and both end of plug wires were secure before heading to work. No difference. I also tried cruise control in manual mode, still has the surge. Cruise control in either auto or manual does make the car not surge as much as long as the RPMs are 1700ish or more. If it's under that, surges equally as much. Someone is selling a Cold Air Inductions CAI in classifieds, I shot them a PM last night saying I was interested. I know it's likely not as good HP-wise as RF, but price is fair and looking nice is a bonus.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#17 | |
#18 |
Thanks for the offer! If the previous owner doesn't come through in a timely manner to get the my OEM intake, may take you up on it. Definitely don't mind paying shipping cost, thanks!
#19 |
Any thoughts on spraying starter fluid (or similar) around the couplings while the engine is running? If it is leaking, it should idle up, correct?
Unsure what starter fluid would do to the carbon (appearance wise), if anything.
#20 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
That maf housing looks dirty. Get a can of maf cleaner from your local auto parts store and clean the maf. It’s a cheap solution to try.
#21 | |
Appears I turned then a little more than needed so the tabs are slightly downwards, with the middle of MAF higher. Potentially a little extra air to get thru and past the gasket. This evening I'll find some washers to add and see if that does any good.
#22 |
Petro-sexual
You gotta get someone to scan with HPTuners or the like. There are so many possibilities it's not even funny. Not all of them will throw a CEL either. I wonder if the previous owner put a tune in the car. Maybe around the 7-8 minutes you said this starts the car could be going into closed loop and that K&N is just throwing everything off. If that CAI has changed the air flow enough (probably not...), torque management could be pulling timing causing that bucking and surging. It looks like that TB is probably stock, so I'd think it's unlikely to be a problem (though not impossible).
Unfortunately - without a stock air box to try, I think either a trip to the shop or someone with something like HPTuners will be the only way to get your answers. That stock air box is probably the best place to go from where you are now. You could try checking/replacing spark plugs or something. At least you could eliminate that. Unless you're putting E85 in it or something, it seems like bad gas is out of the question. This kind of thing sucks...
#23 | |
Petro-sexual
Or - none of that matters, lol...
#24 | |
If no luck I'll check pins on it and TB after a drive if they didn't help. I'll also inspect the mating surfaces closer, adding a thing later of RTV if it's not perfectly level and let it cure overnight. I don't think it's wise to spray the starter fluid by the MAF, but other connections after it should be okay... I think. I have been eyeballing a HTP OBD2/USB for a while for the SLC even though I have no plans of actually doing any tuning I would like ability to adjust a few things on the SLC like the idle speed. I absolutely hate troubleshooting, whole point to buying it was so I didn't have to worry about doing just that, lol. But when I finally get it figured out, it'll be just that much sweeter!
#25 |
Went ahead and purchased the the used cold air inductions (thanks again semif18). After noticing this morning the MAF flange on the K&N is completely flat, but the cold air inductions had spacers on the aluminum flange to compensate for the MAF mount height difference.
Attached comparison pics to explain better I can. May not be my issue, but no matter which way I slice it the K&N MAF flange is definitely not how it should be. Time will tell for sure, but I'll still try some washers this evening to see it'll help. Thanks again for all the feedback, I'm hoping I'm on the right track!
#26 | |
#27 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
HPT for the scanner alone is worth the price of admission.
#28 |
I 100% agree, HPT for the scanner alone is more than worth it's weight in gold. I've been on the edge of ordering one to use on the SLC for a long time, this issue most definitely pushed me over the edge and will ASAP. I've spent more than I needed to for random things for the car over the past few weeks, I need to chill for a bit....but HPT is 100% the next purchase soon.
