Old 07-20-2021, 03:08 PM   #15
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Originally Posted by ZX-10R View Post
Nice - this is probably the route I'll take. 15 psi? 93 pump gas?
Don't trust ethanol and would always have concerns about long term corrosion
12ish PSI on 91, we don't get 93 in Colorado. I totally get the benefits of ethanol but don't see any need in my situation.
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 07-20-2021, 03:11 PM   #16
gotswap
gotswap's Avatar
Originally Posted by MartinLe View Post
So, at pretty much sea level, I should be able to get close to 700. I assume that is on a Dynojet? I will roll mine on a Dynojet a week from today. Awesome numbers on an otherwise stock car!
I think that would be reasonable considering you added headers. May have to ditch the E though.
I have since added an intake and cat back. Next up is a cam, headers and 2nd cat delete. My goal is 800 wheel, will see what happens
2019 Crush A10
E-Force 2650
670WHP 615WTQ
Old 07-20-2021, 05:37 PM   #17
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
+1 - great results for only 12 psi on 91, I'd take that all day
ZX-10R is offline   Reply With Quote
Old 07-20-2021, 07:01 PM   #18
JSH
JSH's Avatar
Drives: '20 ZLE
My mods produce around 765 wheel and it will take Kong's Stage X, and maybe a high side pump and injectors to get to +-815.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 07-20-2021, 08:15 PM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
On long pulls, when I was stock the 2650 to me drove better in the upper rpm from like 4500 rpm to redline especially when it was hot outside It never felt like it was out of power and it kept pulling hard.. The dyno graphs only showed about a 30 or 40 hp increase over a over driven lt4 but it felt so much better.
Sounds like you don't want to go into the motor for a cam right now... What if you got the. Aem 420 lp hour pump, an aftermarket ecu with wide band, port injectors and toohighpsi fuel rails. Or you can do the Kong ported Eforce that has the port injection allocations, AEM pump, and aftermarket ECU.
With one of these setups you can run full E Still.. easily make 800.
Old 07-20-2021, 09:16 PM   #20
Z OH 6
Drives: 2024 CT5-V Blackwing
Originally Posted by CW3SF View Post
The web research I’ve done indicates that corrosion is a concern on full e85 but running a “blend” at less than full e85 pretty much eliminates the corrosive effect.
I ran E85 in my Hellcat for 3 1/2 years straight, daily driver with 28k miles when I sold it. No corrosion issues at all. Modern cars are much more resistant to ethanol.
