Old 07-13-2021, 08:52 PM   #15
boosedep3
Drives: 2018 SS1LE
Mustang dynos are heart breakers, but in the end it is just a number.
boosedep3 is offline   Reply With Quote
Old 07-13-2021, 10:14 PM   #16
This may sound unorthodox, and certainly do clear up the specifics with Ted, but if the car feels like you're gonna s*** your pants when you floor it in second or third, that's all that matters
Old 07-13-2021, 10:20 PM   #17
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Not always
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 07-13-2021, 10:25 PM   #18
Ron_Robinson1
Originally Posted by MartinLe View Post
The tech said I was making 10 psi at 528' elevation on a low 70 degree day. I am going to shoot Ted an email with the pull sheet and see what he says.
Per my previous post asking what gear your pulls were done in.
6th vs 7th gear numbers will be different, I would confirm this first.
Old 07-14-2021, 07:40 AM   #19
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
For the love of God people, rotate your pictures before you post them.
Spaceme1117 is offline   Reply With Quote
Old 07-14-2021, 08:02 AM   #20
wnta1ss
Drives: 2017 Camaro 1SS
Why would the dyno guy give you uncorrected numbers that are over a year apart? The whole point of the dyno is finding out what your changes did, so weather correction is needed. Did he tell you why he gave you an uncorrected sheet? Because the only valid reason to do so would be if his weather station is broken, but he should have told you if that was the case.
Old 07-14-2021, 10:44 AM   #21
Ron_Robinson1
Nope…turn your head
Old 07-14-2021, 10:57 AM   #22
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Originally Posted by Ron_Robinson1 View Post
What gear was the pull in?
Start with that…I also was tuned on a mustang dyno. 95% of my tuning was done in 6th gear. Final pull was done in 7th gear to get my final number. Some shops don’t like taking there dynos to 180-200 mph spins. My car touches 198. I will post my sheets later, but there was definitely a difference in the 6 vs 7th gear pull.
4th gear. I have an M6
Originally Posted by Markoz28 View Post
Was this remote tuned by Ted or the shop doing the dyno?
For reference my first round of mods were 9.1 lower pulley, 2" headers with no cats and Rotofab. Car was tuned by the shop that installed with 579whp on a dynojet. I was disappointed as well and felt the car idle and drive very strange. I took the car to MS tuning 5hrs away and on his Mustang Dyno and no changes it made 556whp. He then did the tune and it made 612whp.
Tuning is a real big deal!
I have since done remote tuning with Ted on last mod revision and I am very pleased with results.
Ted remote tuned the car. He has requested the logs of the run. I will get those today. The car idles as it always did, you know a little rough, but again, just like it did stock. It runs smooth and strong. I have a date with a Dynojet in two weeks.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 07-14-2021, 06:32 PM   #23
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
On a Dynojet showing Corrected numbers, near sea level and with the JRE 125 kit on e60 you should have no problem making 625-650rwhp IMHO. The lower end of that if you are running e40-e50.
CW3SF is offline   Reply With Quote
Old 07-15-2021, 06:18 PM   #24
MartinLe
MartinLe's Avatar
S*** - why, yes sir! Every time I let the dogs out they hunt like there is no tomorrow. And, when I have passengers, even the ones that claim "Badass big block pasts" grin like school boys looking at their first Playboy!
SAE corrected at 571 whp.
I have a date with a Dynojet on the 28th. I'm running e60 at 528' and it should be sub-70 degrees and dry at pull time. I'll post the results.
I sent Ted the logs and he is pleased.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-16-2021, 06:53 AM   #25
wnta1ss
But what was the stock baseline in SAE? You NEED that to know what your mods actually did for horsepower. Weather can vary, and with it, correction factors change.
Old 07-16-2021, 07:11 AM   #26
iwk2much
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD
What wideband did you install? Looking to do remote tuning as well...
iwk2much is offline   Reply With Quote
Old 07-16-2021, 02:03 PM   #27
MartinLe
MartinLe's Avatar
I did not get the SAE numbers from the stock pull (did not know any better). From my limited experience, I should be able to figure out my gains from the upcoming Dynojet session. But, as I posted, Ted saw the pull sheet and logs and he is pleased.
AEM Electronics 30-0334 - AEM Electronics X-Series Wideband UEGO Air/Fuel Sensor Controller Gauge.
Check out this link: https://www.summitracing.com/parts/avm-30-0334
And, STOP working to much!!!
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
