#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LOL negative what? What does that have to do with street tuning? Nothing. Did you not read what i wrote?
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#16 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Yes, here is what you said:
"Wideband isn't needed for street tuning bud, its already dialed in on the dyno. Street tuning is mainly TCM, timing adjustments etc. If the dyno isnt a load dyno the street tune may yield different results as far as detonation or knock. Also, many people run widebands with gauges as well." VVE and all part throttle tuning is best done on the street. You need WB02 for VVE and a half a dozen other calibration level tuning that is performed off dyno. There may be the rare tuner that will attempt to go through the VVE table through varying load over rpm to get through all the zones. Half these guys are using Dynojets out there, it ain't happening with their standard static load units. Once it hits the street it will need to be touched up. Plus it is best to do it over the dynamic of temperature ranges you drive the car in, I don't feel the built in temp compensation is all it is sold to be. To me VVE is a living breathing thing that eventually you will setting on "good enough". I don't see that happening in a single trip dyno session. I am picky and therefore some people may be willing to live with poor street manners, I will not. I actually prefer dyno for final max timing since the car will usually be hotter and you can wind out 4th gear much more safely than on the street. I'm not a fan of multiple 153 mph (M6 car) runs to safely finalize high octane timing tables. I prefer knock on the street, agree with you there. I have gotten different results on street vs. dyno, street tends to show up more for whatever reason.
#17 | |
Moderator
#18 | |
I have been to at least a half of dozen tuners since ive had my car. Not 1 plugs in a widenband for street tuning.. UNLESS, running meth.
#19 |
Moderator
You do NOT need a WB to tune VVE, FYI. It’s only active below ~4000 RPM so the narrowband fuel trims can be used (along with correlating airflow readings vs the MAF). You can use a WB like Greg Banish suggests, but definitely not mandatory.
#20 | |
This year I added 50/50 meth, used WB02 adjustments on street for it, done. No dyno required. Probably took 4 logs to dial it in perfect. You have to have WB02 for VVE. I'd look at your log and see when Dynamic Airflow is enabled. If it is a really low RPM they basically don't have VVE tuned and its just going to high speed (MAF), stock is 4k rpm.
#21 | |
NBO2 aren't going to help give you the proper percent error to update VVE as you walk away from stoich. You would have to spend a lot more time dicking around vs. getting to the proper percent error value quicker. Yes you can do it, but what a waste of time. Additionally you have nothing "checking" that your NB02 values are correct, WB02 always offers second opinion and can tell you if one of them is going south or some quick fueling changes are occurring due to bad spots in a table that NB02 just wouldn't pick up on.
#22 | |
Moderator
![]() FWIW, logging VE airflow vs MAF works mint and is more effective than either WB or narrowband VVE tuning, IMO.
#23 | |
In reference to VE airflow vs MAF airflow for tuning, I don't trust MAF enough at lower rpms to do that across the board. I only compare dynamic airflow vs MAF airflow values to make sure my VVE is right and dynamic is working well. I'll plot the two against each other and make sure they track well with each other. If they don't figure out which ones messed up. Using WB02 I can compare both and address the issue. I always have an exact percent off no matter how wonky the AFR value goes to.
#24 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
#25 | |
Moderator
#26 | |
#27 | |
If you are setting yourself up for a moving hit and have your rpm somewhere lovely like 4500 rpm or so and just holding rpm/mph till its go time, you are necessarily in PE. Get up to speed and park your rpm at 4500 rpm, do you see your PE enrichment expected AFR/lambda showing on your WB02, I bet not.
#28 | |
Moderator
