#15 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Just got off the phone with them. Don't sell a retrofit kit "IMHO stupid" to go from regular to BG. They did say there was no need to go to the BG unless you are over 700RWHP. They did suggest if I was going to a 103 TB to purchase a 4.25" straight coupler to make the regular CAI work with the upgraded TB. Part #10132048, $29.95. Not listed on their website. Figure I would list it here, if anyone was interested.
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Yep, filter area is exactly the same size as mentioned. Its just the elbow that's 5". They sell the dry filter right on roto fabs website... What drugs they smoking? https://www.roto-fab.com/camaro-repl...ilter-dry-type Part #: 10135014 Ive just got mine from summit when i needed. (faster) https://www.summitracing.com/parts/rfc-10135014
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#17 | |
I know the actual brand new assembly only comes with the oiled filter, but they definitely sell the dry filter as a $69 replacement part.
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#19 | |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
#20 |
I got a followup email from them which indicated the part will be on the website in the near future. So maybe this is something new in their product line.
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Would make sense to me Prometheus.
#22 |
![]() Drives: 2020 ZL1 Camaro Join Date: Apr 2021
I put a Big Gulp on my 2020 ZL1 with the stock throttle body. FYI, the BG kit does not come with a coupling to fit the stock throttle body. I had to order it from RotoFab and wait for it to come in while my stock intake was off of the car. Took almost a week to come in. I get it that to get the most benefit from the BG that you need to have a larger throttle body. However, a lot of people don't get around to adding a 103mm TB until later down the road. To me, a stock coupling should be included in the kit. That really pissed me off when I went to install the BG on my car and found out the supplied coupling was too big.
2020 Camaro ZL1 A10
Hawk Performance ceramic brake pads Roto-Fab Big Gulp cold air E85 flex fuel Low temp thermostat Nitto NT555R2 drag radials Custom tuned by MTI-Houston |
#23 | |
This works the other way around. Its meant for high HP applications. Its not meant to attach to the stock size. This is the entire reason they have the smaller one. Even with a 103mm TB on a relatively stock car it does nothing. Your car isnt going to use anymore airflow then it can handle, and the 4" rotofab is more then plenty.
#24 | |
2020 Camaro ZL1 A10
#25 | |
#26 | |
Thank you Al Oppenheiser!
"Standard hardware for this system includes a 5” to 4 ¼“ hose coupler for larger throttle bodies. 4” adapter is sold separately for the factory throttle body." But yeah, I agree with you they could spend the extra $2 and include the stock coupling or be a little more obvious about needing to buy the option on the product page. |
