Old 06-07-2021, 01:28 PM   #15
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I would send this to a shop that rebuilds them, who can also powdercoat.
I wouldn't trust myself to install or fabricate hard brake lines with confidence it wouldn't leak or fail in some way. Last thing I want is a brake failure going into a hard turn a the end of a high speed straight.
SFV1LE is offline   Reply With Quote
Old 06-07-2021, 02:36 PM   #16
gtfoxy
Drives: '21 Wild Cherry ZL1
Aren’t these Brembo’s? If so you could try contacting Brembo OP.
It’s a brake line, not rocket surgery. & a very easy to duplicate one at that as long as it’s not the goofy nipple ended ones. Tubing cutter, flare tool & a simple hand bender.
Just need to find out if it’s standard or metric before you buy the line.
