Old 05-26-2021, 05:25 PM   #15
Badmojo
aka BeastZL1
Badmojo's Avatar
I recommend SRF. The only complaint that I ever hear is price.
Sent from my iPhone using Tapatalk Pro
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 05-26-2021, 05:32 PM   #16
MikeEM1
MikeEM1's Avatar
Drives: Tracks: 18' ZL1 1LE
SRF only.
18' ZL1 1LE Red Hot track toy
Endless RF650
Ported TB/Rotofab dry intake
AWE Track w/PLP
APR GTC300 wing / Singular Endplates
ASC Splitter / PA tunnels
MFR Engineering Custom Diffuser
Race Louvers Fender Vents
Trackspec roll bar
Various SPL suspension
Hawk DTC 70/60 pads
APEX SM10 & ARC8
For sale: 2018 OEM ZL1 1LE Wing
12' Nissan GT-R SOLD
MikeEM1 is offline   Reply With Quote
Old 05-26-2021, 08:30 PM   #17
Apexslayer
Drives: Zl1 1le
SRF is the best, but a little expensive. Motul is nearly as good and a lot cheaper. I stick with SRF as I think its worth the extra cost. One dealer needs 1 litre to flush, the other dealer needs 1.5 (I hate having to waste that remaining 0.5).
Apexslayer is offline   Reply With Quote
Old 05-26-2021, 09:03 PM   #18
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Mmmm. I'll try the 660 out first. Castrol SRF here in Canada is rediculously priced. $170 for 1 litre. I got a deal on the 660 at $50 a litre. The track I frequent is somewhat low speed. The fastest point b4 breaking is around 120kmh. I'll give the Motul a shot first. The OEM dot3 didnt give up until the 6th session. I'm reasoning this was because I only had 10 minutes cool down, as opposed to 40.
Keep the discussion going... I'm learnig lots. I hope others are too?
Crushed 1LE is offline   Reply With Quote
Old 05-26-2021, 09:07 PM   #19
AZIROC
Drives: '86 IROC-Z '18 ZL1
** sorry if its been asked before
Is it ok to change out to the more "track" brake fluid if the car is also on the street ?
Old 05-26-2021, 09:08 PM   #20
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Endless works great as well...
Old 05-26-2021, 09:09 PM   #21
Stephen12ZL1
Drives: '21 ZLE A10
yes...you can use high temp fluid for street use
Old 05-26-2021, 11:49 PM   #22
AZIROC
Thanks. I've been looking to make my car a track car but sometimes go to show and such sometimes too.
Old 03-27-2024, 09:04 AM   #23
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
For those tracking their car and using Brembo HTC64, how often are you bleeding it? I recently switched from Endless to Brembo, so I wasn't sure if Brembo needed to be bled every couple of track days, or if it was good several. Thanks in advance!
Texan4iu is offline   Reply With Quote
Old 03-27-2024, 02:19 PM   #24
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Buy the best cheap fluid you can get, bleed often. We used to track w Castrol LMA until it was discontinued. Now, BRF 600 or 660 and.. bleed often.
ing for grip.
http://www.motorsportsne.com/
Old 03-27-2024, 04:41 PM   #25
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
No issues with Motul RBF660 with multiple track days.
SSEssence is offline   Reply With Quote
Old 03-27-2024, 05:41 PM   #26
AZ_1LE
Drives: 2019 ZL1 1LE
Yea, SRF is the way to go. Only issue is having to flush it out every year or so because it absorbs water more quickly than DOT3 (which is why they use DOT3 from the factory).
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 03-28-2024, 05:32 PM   #27
Vigilante375
Drives: 2018 Camaro ZL1
It was said that in 2023 or 2022 they started to fill the ZL1s with DOT4.
Old 03-28-2024, 06:47 PM   #28
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Dot3 absorbs less moisture so I’m guessing no on dot4 from the factory. GM does not want to be like Ferrari were they demand a $10,000 service every year. Besides probably listed on the fill cap.
