#15 |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
If you measure, be sure to sand the rotors first to remove the pad deposits. That way you're only measuring the rotor itself.
#16 |
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
Rotors dont warp, its pad deposits. I can't believe people still perpetuate that myth.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
#17 |
![]() Drives: 2024 Radiant Red 2SS, 1994 Z28, Join Date: Jan 2013
The dealer actually measured the rotors and found the runout to be out .008 on one side and .005 on the other side
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
A good read:
https://centricparts.com/getmedia/bd...c-8-2018_1.pdf I agree with Travis and the uneven transfer crowd here. 99 times out of 100 it’s going to be uneven transfer. And to appease Murphy’s Law, The other 1 out of 100 is going to be someone who extremely abused their brakes then drove thru flood waters, lol. Buy this and clean off the uneven deposits: https://www.amazon.com/dp/B007INTEMC...v_ov_lig_dp_it There is a rare chance that if the car was driven a lot of miles with the uneven deposits, and the brakes were used hard to the point where the vibrations got extremely worse, that could negatively change the metallurgical properties of the iron. This change will perpetuate the uneven transfer layer. But if caught early, the rotors can be renewed to a fresh surface. Travis mentioned washing the car and not getting the brakes dry, I agree with this also. And I also found that some wheel cleaners can remove transfer layer and cause pedal vibrations. I used to use Meguiar’s purple spray bottle wheel cleaner. I now use their wheel cleaner in the blue bottle. The rotors on the SS 1LE and ZL1s are Brembo. I can’t say if a regular SS has Brembo rotors though.
"KEEP THE FAITH"-Fbodfather |
#19 |
Drives: 2021 Camaro 1LE Join Date: Mar 2021
#20 |
Runout and warping are two very very different things.
#21 |
#22 |
A quick google will teach you everything you need to know. You really should stick around, you could learn something, cognitive dissonance is such a shame really.
#23 | |
![]() Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
I don't actually use a dedicated wheel cleaner. Car shampoo, wheel brush, and horsehair detailing brush for the delicate areas only. |
#24 |
#25 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
#26 |
Seems like all the articles online that I've read about the "misconception of brake rotor warping" hone in on the premise that you don't have "warping", just uneven wear. Excess runout typically occurs from the pads wearing the rotors unevenly, probably due to an imbalance in the rotor. It's not "warping" like you'd see with a piece of wood, but the essence of it is the same: it's a physical imperfection in the rotor surface, causing the pad to make inconsistent contact with the rotor. Whether you call it a warp or uneven wear, the available solutions are the same: re-surface the rotor, or replace it.
For the record, I don't see anything like "uneven pad deposit" on my rotors. I've researched and seen photos of this and that's not what's going on here. I imagine the solution for that would be to lightly scuff the rotors with some high grit sandpaper or to use something like the drill attachment linked earlier. Any time the wheels are removed and re-mounted, there's a chance that they'll be remounted unevenly and cause uneven wear. My take-aways here are to tighten down lugs in a star pattern always (or re-do the job correctly after you hand the car to someone else to rotate/balance, etc.), and make sure to get brakes dry after a wash and drive it afterward for a few minutes. |
#27 |
Don't overlook any corrosion on the wheel, rotor hat and wheel bearing faces. Any corrosion here can cause runout.
#28 |
