#15 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
I'd add the mag puck as the jack you selected is not completely flat.
#16 | |
That magnetic one does NOT stay on the car. The lift pads (4 in a kit) are the ones that stay on the car. There's a link in my previous post.
#17 |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
The mag pad is a single. The lift pads come in a set of 4
#18 | |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
#19 | |
Except they are sold out right now... https://zl1addons.com/collections/ja...-3-jack-magpad I use this one all the time. I've even forgotten and left it attached during an entire track session and it never came off. This one lifts both front and rear tire at the same time. Then just move it to the other side. Nice low profile jack from Harbor Freight as mentioned and you're good to go. I'm sure they will get the pucks back in stock and you can order that separately. I also have a set of the ones that stay on the car but never installed them. Mainly wanted those for incase a shop was jacking my car they would see the red jack points. |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I've got two of these:
https://zl1addons.com/collections/ja...-3-jack-magpad Work just fine with two jacks.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#21 |
![]() ![]() Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
https://www.ebay.co.uk/itm/233607190...4AAOSwSTpb0Bxs
just ordered one of these. hopefully it'll do the job. will line it with some thin rubber.
#22 |
![]() Drives: 2021 Camaro LT1 Join Date: Oct 2020
https://www.amazon.com/gp/product/B0...A3OF82XRVO3DTV
For the lift pads suggested! This review says it didn't fit his 2020??? 3.0 out of 5 stars Well made product just didn't quite fit my 2020 Camaro Reviewed in the United States on July 30, 2020Verified PurchaseEarly Reviewer Rewards(What's this?) They are a well made, solid product. Unfortunately the slotted part that goes over the pinch weld was not quite deep enough. I was able to return them with no problem though. I'm hoping they will make them to fit my 2020 Camaro. |
#23 | |
So do i need both the lift pads (that don't appear to fit a 2020 ?) and the magnetic jack pad? |
#24 |
![]() Drives: 2019 2SS Join Date: Mar 2018
Does anybody uses suspension parts for jack stands? I have installed lift pads on all 4 corners but still have no idea where to place jack stands.
#25 |
Jaxcam02's video on page one shows that.
#26 | |
![]() One in the center lifts both front and back. |
#27 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Does anyone know what size magnetic pad is needed in regards to the width of the opening? The zl1 add ons is sold out so I need on from amazon. I know I need the 3 inch length one but what about the width of the opening? There are two options. .39 and .55 inch.
#28 |
It's the most confusing topic of all time
At this point I have new wheels and tires coming, and only the low profile jack ordered. I'm so confused on what I need. Why would ya need the magnetic anything if jacking up the front and rear on flat cross members?I get the lift pads for the sides now, I understand that part. |
