Old 04-25-2021, 10:50 AM   #15
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
Originally Posted by 6spdhyperblue View Post
Does the corsa closed really seem louder than npp open?
Love the amount of difference in db but def can’t have the car that much louder when closed
I don’t think so, but I can’t really measure it, stealth/tour mode is quiet and seems to work to my ears.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 06-01-2021, 02:30 PM   #16
JitteryJoe
Drives: 21' LTI, '18 Traverse, '15 Mazda 6
This was the closest similar thread I could find to post the question in (search seems to always take me to an error page).
I stumbled across an NPP exhaust for sale on marketplace on the cheap. How hard is would it be to retrofit on the cheap? I imagine I would need the proper diffuser and then some sort of way to control the valves (either aftermarket or the proper oem wiring and then reprogramming whatever modules control it).
any other potential problems? I heard the valves have had issues but this is allegedly from a 2021 so hopefully it would be figured out by then?
Worst case scenario it would be stuck open if I just bolted it up right? Could I delete the valves entirely if they turn out to have issues?
JitteryJoe is offline   Reply With Quote
Old 06-01-2021, 02:46 PM   #17
enzia35
Drives: '16 Garnet Red 1SS
I've not heard of anyone upgrading the infotainment for NPP. Honestly, I would have looked for an NPP car specifically instead of hacking up something to work after the fact.
'16 Camaro 1SS
'18 Miata GT
Old 06-01-2021, 02:59 PM   #18
Zr8000
Drives: Chevy Camaro
I have read you can turn the npp on with an hp tuner and most people don’t because they don’t want to buy a 500 dollar tuner on top of the exhaust to turn it on. I have not actually done that myself. Just what I read.
Zr8000 is offline   Reply With Quote
Old 06-01-2021, 03:04 PM   #19
JitteryJoe
Yeah, the only real driver is cost. If I can hook up an dual mode exhaust for $300 + 100ish for a diffuser + $20 for a switch and wiring I feel like that would be better than a $400 muffler delete or $700 axle back that would sound like shit because I don't want to spend 2k on a "real" exhaust.
I've done a google search too and it's just crazy that there doesn't seem to be any answer here. it can't be that hard to send the power/signal to the actuators to tell them to close? can it?
Old 06-03-2021, 06:48 AM   #20
J20192SS
J20192SS's Avatar
Drives: 2019 camaro 2ss
I also had the same question, so I emailed Corsa and they confirmed that the sound levels being quoted in this thread were from a combination of the axle-back + X-pipe, which they no longer offer. As of today, Corsa is not providing this detailed sound level data available for ONLY the axle-back. However, Corsa did clarify two points:
1) The difference in their kit being closed and open (track mode) is 12 dB.
2) When the valves are open in track mode, the kit is 12 dB louder than the factory track mode.
Unfortunately, no other details were provided regarding the RPM at which these sound levels were recorded.
J20192SS is offline   Reply With Quote
Old 06-03-2021, 07:25 AM   #21
That is freaking loud, with the factory NPP exhaust already at a not too shabby ~95 dB. This also means Corsa has to feel more than twice as loud.
Old 06-03-2021, 07:35 AM   #22
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It's much louder then stock NPP open. Closed its not much louder at all. The 12db difference is between open and closed not stock npp open vs Corsa open. The Corsa NPP is excellent. It's literally mild to wild. But even when cruising around at lower RPM with the valves open it's not that loud. It gets louder as RPM's increase. 2k RPM on up it gets loud.
Old 06-03-2021, 02:44 PM   #23
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
They are probably running the SAE static test which puts it around 2500 RPM. So not even close to full throttle.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
