#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
I also bent a sharp 90° angle in one of these type tools for removing the plug. The length of the tool and throat of the 90° angle made it easy to remove.
#16 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
So I am in the middle of the trans fluid change. Pretty easy so far. I am glad I decided to do the fluid change as I have discovered two issues. First, there is a bit of a dent in the trans pan, looks like someone tried to jack the car on part of the pan as it was pushed in on one corner about 1/4 inch. I was able to push the dent out without too much effort. Second, I have discovered that the fluid level in the car is likely low. When I dropped the pan, I caught all of the fluid. I removed the filter and emptied it out also. The fluid was warmed up also. I made sure the measure the volume and only 4 quarts cam out. Everything I have read or watched on the A8 fluid change says to expect about 7 quarts out. Want to bet when the fluid was changed or flushed, it was done incorrectly at a dealership? I'd take that bet. Whoever did a change or flush likely didn't warm the fluid up or check it with the car running. Probably both. This is why I do all work on my cars myself. |
#17 | |
I’d take that bet too! Agreed! I’d rather do it myself. If I mess up, I know it and I’ll fix it. If dealer messes up it turns into damage control mode. Did you get this buttoned up?
#18 | |
But yeah, 4 quarts came out and it took 7 quarts to fill until fluid was starting to come out the overflow with the engine running. Let the car run a bit to get the fluid mixed. I then shut it down and dropped the front of the pan to get more old fluid out and put 4.5 quarts in. Let the car warm up to proper temp and drained the excess from the overflow. Figure I was able to get the majority of the old fluid out. Wasn’t much debris on the magnets and the car never set any codes so I don’t think there was any damage done. Just glad I got it set right. |
#19 |
That’s good piece of mind. There’s nothing like “knowing” the job was completed the way you wanted.
#20 | |
![]() Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
I have 52k miles on mine. Don't really feel any shuddering but I want to get it changed with the new fluid. I plan on following this guys video:
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
i followed that guy's video (even bought the quick jacks and vacuum etc).
yea, you go thru a lot of fluid (you need basically twice as much as the capacity to do a near complete change and it takes a couple days at least to do (with drainings over night to be ideal) i dropped my pan and changed out the filter too. It wasn't clean in there (only had about 40k miles after 5 years). Proper fill and levelling requires getting the fluid to proper temperature (which can take a long time if the trans is just idling) and the car has to be lifted level. You wont be saving much money if you have a dealer who charges you something reasonable and they use the flush machine and the right fluid. But ...those are a lot of iff's that may not be things you can rely on...depending on your dealer. It was less convenient, but i know it's getting done with the right stuff doing it myself. And no issues since. |
#22 |
I'm quite a few pounds and inches of muscle away from this video, oh well.
#23 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
The Chevy dealer can't even do a SS tire rotation properly. I certainly wouldn't trust them doing a tranny flush on my SS and screw that up. My SS is used. My 2016ss was bought by it's past owners in 2015 so I assume I'd have to pay for the TSB anyway if I want it done. |
#24 | |
#25 |
![]() Drives: HHR Join Date: Dec 2015
#26 | ||
Damn! I wish I looked like him all ripped combined with a pretty car like that!! |
#27 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
2012 Yukon XL Denali w/ 6.2 AWD |
#28 |
Just got mine changed yesterday. I got 7.5 quarts out. So far it seems to shift smoother. Especially 1-2 shift. Before it would be really rough sometimes. Now it's pretty much smooth every time. I'd say shudder is mostly fixed now. Probably not all the way just because there's still some old fluid in there. I'll probably do another drain and fill in the next few thousand miles just to get most of the old fluid out.
