#15 | |
![]() Drives: 2018 2SS M6 Hot Wheels Camaro Join Date: Mar 2017
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars: 2017 1SS Nightfall Gray Metallic w/A8 and NPP 1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps. |
#16 |
As far as the draw on the battery, that is pretty much what I figured. I mean, I wasn’t worried about that being an issue, but it still concerned me if they weren’t supposed to be on for that long after it was locked and armed. It just seems like it may be an indication that something is wrong, that’s if they shouldn’t stay on that long. A couple of people in this thread have indicated that theirs behave the same way as mine, which is only more confusing, if others do not. These cars are enigmas!
#17 | |||
Hot Camaro
First, the light in the center of the dash should come on SOLID when the car is locked and remain that way for about 30 seconds before changing to a one blink every two seconds pattery. The solid light would indicate that the car is fully secured and the alarm is ready to arm. The change to what the manual calls "slow blink" mode indicates that the alarm is armed. If the dash light comes on in a fast blink pattern (what I had observed) for 30 seconds, it is an indication that the car is NOT properly secured. In my case, the hood was not latched but similar would happen if the trunk were open or a door. When I tested again last night, I could not seem to get the light on door handle to go out in under 10 minutes although the day before it went off every time at the 90 second mark. Not sure what has changed as in both cases the car hadn't been driven. The ONLY difference was that the battery was fully topped off during the first test as the car had been connected to a tender. For last night's experimenting, the battery was not at 100% as I had not reset a fault that would allow the tender to go back into operation. There seems to be zero information in the manual as to how the lights on the door should work (or that they even exist). |
#18 | |
Drives: Fast if no one's looking Join Date: Aug 2019
At least it requires 2 full pulls. Starting in the late 1960s on Fords when you locked the doors they could still be unlocked and opened with one pull from the inside. |
#19 |
Hot Camaro
Didn't realize it was that far back! I remember a few different vehicles that the door would open with a single pull whether locked or not. I think that was mostly from the 90's, maybe?
#20 | |
It was the Lincoln Mark series coupes that first used it as auto theft was rising. Then by the mid-70s all Fords/Lincolns/Mercurys had it. |
