Old 03-23-2021, 07:02 PM   #15
Originally Posted by thegraham77 View Post
Ok...if this is a stupid question please let me know, after you guys answer it of course ��. 2019 a10 ZLE-do I have AFM or no? I have never felt it and really haven’t found a straight answer. Maybe it just switches that good that I don’t notice?
It should be disabled on your car. You can double-check this yourself by flipping to one of the mpg info pages in the gauge cluster that displays a gray V8 icon: if it ever turns into a green V4 icon when cruising in high gear, that's AFM kicking in. But again, as far as I know, AFM is not enabled on A10 ZL1s.
Old 03-23-2021, 07:38 PM   #16
thegraham77
Drives: 2016 GMC Canyon All Terrain
Ok awesome. Thanks. I’ve never seen a V4 icon. Come to think of it, I don’t ever remember seeing a V8 icon either.
2019 A10 ZL1 1LE. Shock
thegraham77 is offline   Reply With Quote
Old 03-23-2021, 07:44 PM   #17
Bruiser SS
Bruiser SS's Avatar
Drives: 2023 Chevy Camaro ZL1 A10
AFM has been great on my 2020 A10 2SS. Doesn't make much of a noticeable transition at all. It was more noticeable after exhaust but still nothing bad.
Bruiser SS is offline   Reply With Quote
Old 03-23-2021, 08:16 PM   #18
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
AFM is annoying to any of us with a sensitive butt meter and a sharp ear. I can feel it, hear it all the time, constantly taping on the gas pedal in slow traffic to knock it out. When its engaged in slow traffic, the up shifts are not nice and crisp, the automatic down shift when the car slows down is different etc etc. Just give me a switch to turn it off and I will be happy. Mechanically its altering the way the lifters normally work and it makes the converter do extra work. The less any mechanical or electrical component does, the longer it will last. Certainly not worth the 1 or 2 MPG gain.
lt4camaro is offline   Reply With Quote
Old 03-23-2021, 08:53 PM   #19
shoe5163
Drives: 2017 50th Anniversary SS
Or econo mode with 4 all the time.
shoe5163 is offline   Reply With Quote
Old 03-23-2021, 09:21 PM   #20
Just for the record, it looked like this in the pre-refresh cluster, I don't think GM changed it that much in 2019 cars (and yes, it's black on green, the photo isn't exactly color accurate):
Old 03-24-2021, 03:47 PM   #21
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Some of us simply don't trust AFM as a technology:
- it's hardwired to the same 4 cylinders, which may impact wear uniformity;
- switching between V8/V6 and V4 modes is done via valves that can creak or whine;
- the A8 (8L45 and 8L90) trans is tuned differently in DoD (AFM enabled) mode, allowing much more torque converter slip that then triggered the shudder issue much sooner and more readily for many
All these risks for a 1-1.5 mpg gain. The successor to this technology, DFM is more advanced, but the Camaro did not receive it, and you know how it is with complexity in general, the higher it gets for a component, the more prone it is to fail.
I heard about that being the case with number one.
Never heard of example number two you provided. I really need to get a range device.
ItsChristianInHD is offline   Reply With Quote
Old 03-24-2021, 04:44 PM   #22
GroundhogSS
GroundhogSS's Avatar
I've been using the Range device since they got the software to where it didn't throw codes. Originally I got TCM codes and sometimes very rough shifts (A8). Cruising on the highway it still gets in the 20's. Better than my G35 coupe ever did.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 03-24-2021, 04:56 PM   #23
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Being an M6, mine doesn't have the software to enable the AFM.
In my C7 M7, I have tried it and I didn't mind it. With C7, if you have M7 then it will only engage in Eco mode. The only way I was able to tell is with the indicator and the subtle variation of vibration in the shifter. Otherwise, it's very smooth.
Personally, I wish Camaro M6 is programmed like C7. My daily driving won't see much benefit from AFM but for the long highway trips, it could help. For people who don't like it, don't turn it to Eco mode and it will never bother you.
As for oil consumption, if it's anything like Honda's VCM troubles, then it's probably due to the slow leakage of gas from the disabled cylinders, which over time can create a vacuum in the cylinder and it will start sucking in oil. I have heard GM combats this issue now by having a combustion event happen once in a while in the disabled cylinder just so that the cylinder pressure stays up.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 03-24-2021, 07:56 PM   #24
I'll have to clarify my sloppy wording there, there is a second set of valves (in addition to the exhaust control valves) under the car that are flipped when AFM engages V4 mode in order to mitigate unwanted sounds. So these don't perform the AFM function per se, they're intended to address a side effect.
Old 03-24-2021, 11:17 PM   #25
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Those valves are interesting, I always thought they were to maintain a good sound from the exhaust but on the v6 those valves are just spring controlled rather then electronically controlled like NPP.
2016 1LT v6
- Totaled
Happiness: Infinite
Old 03-25-2021, 10:20 PM   #26
Soon2be 21SS
Soon2be 21SS's Avatar
Drives: 2021 Camaro 2SS Convertible
So are you saying then that, for instance in a 2021 A10 Camaro, if you have it in sport mode it will not initiate AFM at all?
Soon2be 21SS is offline   Reply With Quote
Old 03-26-2021, 02:16 AM   #27
UnknownJinX
Technically it can kick in in all modes if the conditions are right.
Current:
Past:
Old 03-26-2021, 08:07 AM   #28
Seniorrs
Drives: 21 Camaro RS manual v6.Tyota Tacoma
Scotty Kilmer says deactivated cylinders wear more because of lack of lubrication.Same cylinders deactivate all time.I don't have to worry about that or remote start with manual.But I think I would deactivate if I had auto.
I think it helps sales.
Seniorrs is offline   Reply With Quote
