#15 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I also noticed condensation leaking from every other connection Is that normal ? There not leaking fumes just water.
I'm really going to have to figure something out with the ball and socket connection because it will drive me crazy. |
#16 |
![]() Drives: 2017 ZL1 Join Date: Apr 2020
They should not leak . I have the long system with no leaks.
2017 ZL1 M6 Silver Ice Metallic
#17 |
So I just did the vacuum, soap and water test and every single joint had bubbles. I'm taking every apart again and putting Permatex high heat sealer on every joint.
#18 |
![]() Drives: 18 ZL1 mostly stock Join Date: Jan 2020
That's exactly what I used, no more leaks!
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's |
#19 |
So I took everything apart and everything is nice and leak proof except the 2 bullshit ball and socket joints still leak minor. I'm thinking it's because the clamps go all around and leave like 1/2" gap between the two ends of the clamp.
