03-23-2021, 10:59 AM | #15 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
03-23-2021, 11:01 AM | #16 | |
03-23-2021, 11:25 AM | #17 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Not sure how a piece of billet could 'fall apart'. If you are referring to the hinged hooks, I'm not a fan of that design in general, as there are more pieces to fail if you actually need it.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-23-2021, 11:35 AM | #18 |
Well obviously not the billet part. The hinge area I believe. I liked the flat one pc. Type I had on my fifth gen, though it was a permanent fixture, which was fine with me
03-25-2021, 04:47 PM | #19 |
Drives: SS 1le coming Join Date: Sep 2020
08-31-2023, 07:45 PM | #20 |
Drives: Camaro Zl1 Join Date: Jun 2023
the zl1 addon hook has an adjustable circular metal ring which makes the screw shorter and allows it to stick out of the zl1 1le version of the car a little further thus clearing the front facia of the grille. The question is, how much of that screw still has to be screwed into the camaro to tow, before it becomes an issue? Maybe that's why you saw 1 explode? in the past? Because it wasn't installed correctly? Or are you claiming the zl1 addon tow hooks are all defective? What's the story?
09-19-2023, 10:00 AM | #21 |
Drives: Camaro ZL1 Join Date: Sep 2023
What’s the deal with the tow hooks? I understand we need them if we are to be towed. Having them exposed all the time? Is it just me me or is this a trend in need of fading out. These aren’t recovery vehicles.
09-19-2023, 07:26 PM | #22 | |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
It's good common courtesy if you track your car to have a tow hook, some clubs require them. It makes it quicker to get your car off the track in the event of an incident and allows the session to restart quicker. Street car..... Poser |
09-24-2023, 10:32 AM | #23 |
Not sure what kind of tow hook you have, or about your front grill... But the tow hook i bought from zl1 addons has a small washer like screw that is adjustable with an alen key. This allows you to screw it into the hole at the front of the camaro, and when tightened if adjusted properly should clear the front facia of your camaro without issue and leave enough of the screw in to be able to tow.
09-24-2023, 09:33 PM | #24 |
Drives: '19 Camaro M1SS1LE Join Date: Aug 2020
Where's the tab for the screw driver? Can you show me in the pics?
09-25-2023, 12:02 PM | #25 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
I put mine in after that, but I do remove it after trackdays. On a pre '19 model, it's pretty easy to pop out the grill piece. |
09-25-2023, 12:07 PM | #26 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
pro tip from experience, use a little blue loctite and get your stuff set straight. Mine would vibe loose and be crooked.
09-26-2023, 06:41 PM | #27 |
Drives: '23 Chevy Camaro 2SS Convertible Join Date: Nov 2022
Here (photo).
There is a notch that you can push a plastic trim removal tool or a flat-head screw driver. Push IN toward the radiator, and the lever action of the tool will pry the top of the access hatch down and out. Look also at the bottom of the trim piece as there is a plastic tab that locks the bottom of the hatch in place. You'll notice that the ZL1 add-ons tow hook does actually "fit" with the unaltered hatch piece in place. There is enough flex in top fin of the hatch to allow you to pop the piece back in place. However, as you can see from the photo, it leaves a small gap between the top of the access hatch and the rest of the bumper. I'm considering whether to do the Dremel sanding drum mod to remove the small gap. I'd like to avoid modifying the original trim piece if possible. Last edited by dting22; 09-28-2023 at 10:10 AM. |
09-26-2023, 06:48 PM | #28 |
There's a reason beyond track day for why we Camaro drivers should consider mounting a tow hook permanently: getting the access hatch open in order to install the factory tow hook is a real PITA. Sure, once you figure out how to do it, it makes sense. But if it's a rainy or freezing day (the kind of conditions where you might find yourself spun off the side of the road), hunting around for a trim removal tool and flashlight and fumbling around in the dark trying to install the tow hook seems like a problem worth solving with a permanent track-day hook.
