Old 03-03-2021, 12:12 PM   #15
Alain
Alain's Avatar
Sorry to hear about this !! My car has been sitting since early November here in NJ. I’m gearing up to bring it out of hibernation by the end of March, hearing this makes me nervous.
For some reason I feel like this issue (cylinder misfire) has been talked about quite a bit here on the forum.
Like others have mentioned, check for bad/corroded connectors, bad plugs. I doubt it would be bad fuel. I haven’t used any stabilizers in any of my cars in 5 years and I’ve never had an issue with bad fuel.
Let us know what you get.
2018 ZL1 1LE/Red hot
Old 03-03-2021, 08:14 PM   #16
Tuner2muscle
Drives: 2019 Camaro ZL1
Pull the cover off my whip and went to get the kids at school...... sans insurance...
2 miles of smiles..............
Tuner2muscle is offline   Reply With Quote
Old 03-04-2021, 10:16 AM   #17
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
It's stored in a very clean and heated environment on the GM battery maintainer. How does a plug wire or injector just simply "go bad" without running at all. Should I just be unplugging each and re-plugging them to diagnose? I don't think spark plugs are an easy job on these suckers too. Haven't been under there in a year or so though.
Ran absolutely perfect before putting away last fall. I'm going to take a look at it over the weekend if I can and let you all know.
Stored with a full tank of 93. Didn't put a stabilizer in but have also never had issues on any of my 7+ cars each spring.
Old 03-04-2021, 10:43 AM   #18
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Rats.
Old 03-04-2021, 11:23 AM   #19
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Collapsed AFM lifter, Injector stuck, Bad wiring-(varmint chewed).
Old 03-04-2021, 11:46 AM   #20
Alain
Alain's Avatar
Looks g forward to the update !
Old 03-30-2021, 01:30 PM   #21
Can'tHave2MuchHP
Drives: Fast
Got the update and very happy it's an easy fix. Bad plug on #4.
Isolated each piece of the puzzle from Coil, wires, etc. Thought for sure it would be an injector but the issue followed the plug when I swapped it to another cylinder.
Old 03-30-2021, 02:16 PM   #22
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Awesome easy fix, glad wasn’t anything else.
Then again you need to be a contortionist a bit on passenger side to change those plugs
Old 03-30-2021, 03:25 PM   #23
Can'tHave2MuchHP
Drives: Fast
Understatement. I about dislocated my fingers and wrists doing it.
Old 03-30-2021, 03:36 PM   #24
Twist ZL1
Twist ZL1's Avatar
Drives: Camaro ZL1
I'm taking mine out of storage this weekend (about 2 hours away from where I live). Im a little nervous now. At least if it throws a code I know where to look first.
Twist ZL1 is offline   Reply With Quote
Old 03-30-2021, 04:01 PM   #25
EvilZL
EvilZL's Avatar
Drives: 2018 Camaro ZL1
Good to hear it was an easy fix!
I pulled mine out of my garage from winter storage about 2 1/2 weeks ago, fired right up. It was nice to start taking some rides again
EvilZL is offline   Reply With Quote
Old 03-30-2021, 04:01 PM   #26
hawk02
Coupe Newbie
hawk02's Avatar
I’ve been in Florida all winter. Haven’t driven my ZL1 since last November. I filled the tank up, threw in some Stabil, and attached a trickle charger on the battery. I got my fingers crossed it starts right up when I get home on the 15th.
Old 03-30-2021, 10:06 PM   #27
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
A family member Z06 C6 is doing this right now, and my son's 2016 Silverado had to be towed to the chevy dealer last week I'm glad it's certified, the check engine light says bad fuel pump or direct injection, all it does is turn over, both vehicles had marine grade stabile, I'm thinking this ethanol is so bad it's still messing up everything, I'm putting non ethanol 93 in all my toys from now on, and still a dose of fuel stabilizer anyway.
Revalot is offline   Reply With Quote
Old 03-30-2021, 10:10 PM   #28
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Ha ya, when your knuckles bleed you know its a job well done. That side really does suck. Probably faster to remove the coolant expansion tank and move to the side.
