Old 04-14-2021, 12:05 PM   #15
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
got them installed in october got alignment last weekend no changes 4 track days not bad and definately worth the $$
and you gotta stop hitting those curbs/berms so hard haha
Old 04-14-2021, 02:09 PM   #16
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I have the BMR parts which do the same thing, albeit heavier but also less expensive. I would have bought these instead if I’d known.
After 7 good track days, I still need some realignment after a track weekend or 2. The parts don’t move they are locked in place and the jam nuts are not coming loose.
I asked my shop in LA about this, JMP Autowerkz, who specialize in BMW track cars. They’ve installed the same spherical parts on many makes/models and say these do not prevent need for realignment. I was a little disappointed and worried maybe I was bending stuff, they said it’s normal and no issue getting car back to desired spec so no bent parts.
SFV1LE is offline   Reply With Quote
Old 04-14-2021, 02:18 PM   #17
kropscamaro16
JMP Autowerkz does some good work they built my buddys time attack m3 ls3 for him
Old 04-14-2021, 05:41 PM   #18
SFV1LE
E46 or E36? I think I saw an E36 LS M3 in there, those are very badass, a great use of an LS swap IMO. E46 I would keep the M motor if possible, amazing how fast a good E46 track car with basically stock HP can still be at Buttonwillow with a great driver. I think Mohammed the JMP owner said someone was doing 1:50s.
Old 04-14-2021, 06:10 PM   #19
kropscamaro16
e36 m3 blue and white with full cage and wing its their race car and yea the blue m3 ls powered one does around the same flying...i only did a 2:02 my last time there hoping to get sub 2 when i go back in may with ongrid
Old 04-14-2021, 07:05 PM   #20
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
same here...alignment has been rock solid which is amazing compared to my '17.
Old 04-17-2021, 01:57 PM   #21
SloCal
SloCal's Avatar
Drives: 2018 2SS 1LE
They built a sick ls7 e46 m3 that blew up at buttonwillow lol.
I can’t help it on the curbs I can only go max attack to embarrass the bmw/Porsche crews. Thanks all going to buy these and install. My rear toe literally goes out after one session with these shit stock arms/bolts. Only downside to 1le so far
2018 1LE
2nd 6th gen
SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid
SloCal is offline   Reply With Quote
Old 04-17-2021, 05:34 PM   #22
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
If it holds, ill get them. Sebring kills alignments and dealer is up to $350 for track alignment in my area...
Timbo-1LE is offline   Reply With Quote
Old 04-24-2021, 01:10 AM   #23
SFV1LE
IMO you should not be going to a dealer for alignment. There are some good tracks in FL as far as I know, there has to be a good performance/track focused alignment or overall performance shop that does great alignment. The best places in Los Angeles charge $120 for track alignment, more for corner balance.
$350 is what dealers might charge when they also have to rotate DSSV camber plates from street to track on a ZLE. Does the SS 1LE have similar camber plates?
Old 04-24-2021, 09:10 AM   #24
SloCal
SloCal's Avatar
You talking about west end? Think they charge 150 now. Or is that just to me...?
2018 1LE
2nd 6th gen
Old 04-24-2021, 06:07 PM   #25
Badmojo
aka BeastZL1
Badmojo's Avatar
I ran these for the first time this month and highly recommend them.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-24-2021, 07:51 PM   #26
SloCal
SloCal's Avatar
Did you measure toe before/after track day?
2018 1LE
2nd 6th gen
Old 04-25-2021, 10:52 AM   #27
SFV1LE
Are they $150 now? I go to JMP now because they’re much closer, I think it’s $120 there as well as other good alignment shop in my neighborhood. If they aren’t all $150 I’m sure they will be soon.
Old 04-25-2021, 11:11 AM   #28
SloCal
SloCal's Avatar
Yeah. And just to add jmp doesn’t let you sit in car and uses lasers. Have tried them all and none come close to west end despite the inconvenience
2018 1LE
2nd 6th gen
