#15 |
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Even Porsche GT cars only get charged $450 for an oil change.
So anything over $200+ for a Chevy is a big no no. Sorry.
#SAVETHEMANUALS
#16 |
Hot Camaro
If you are using the car on the track, and you intend to ensure you don't void your warranty, you need to use 0W-40 dexos2 oil. If you are NOT tracking the car, you can use 5W-30 dexos1.
Personally, my car will NEVER see the track, so I have no issue using Kirkland (Costco) 5W-30 dexos1 Gen2 oil (and it's on GM's list of approved oils) which costs me under $30 for two 5 quart jugs. With a Mobil 1 filter, cost out of my pocket is $40 and it's super easy to do it in my own garage in about 20-30 minutes. |
#17 |
![]() Drives: 2021 Camaro LT1 Join Date: Oct 2020
They said it requires Mobil 1 ESP 0W-40. Which I found online for $7.81 per quart as opposed to their $18.77. I've had a good exchange with their dealer rep, we'll see what he has to say about that kind of markup.
#18 | |
Hot Camaro
This is no different than when the Gen6 first came out except that GM stated you needed to use 5W-30 dexos1 but for track use you needed to change to 0W-40 dexos2. All they did was flip the standard and the exception. Use cases have not changed nor has the required oil that goes with them. |
#19 |
That was my next step. You have to realize I just assumed it was going to be around $100 or $125 so I didn't ask.
#20 | |
![]() Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
Now on to filter? They list the AC Delco and then other supposedly higher quality filters from Wix and others. In my truck I use the stock Ford filters because they have an anti drain back valve of sorts supposed to limit the dry start up. That was what everyone recommended over even ones costing more. What are people using in their Camaros?
#21 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#22 |
![]() Drives: 2019 2SS 1LE Join Date: Feb 2021
My "new to me" 2019 1LE goes for an oil change tomorrow. The PO did it himself, so there is no maintenance history, so I wanted to get that started. I was quoted $69 for an oil change. I'm assuming they're using dexos 1 5w30 for it. Will I get better protection using the 0w40? My Scat used 0w40 and it was $190 every oil change.
#23 | |
Hot Camaro
#24 | |
#25 | |
Hot Camaro
#26 |
![]() ![]() Drives: 2015commemorative vert 2SS Join Date: Oct 2013
They should be ashamed to charge that much.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
#27 |
Well not surprisingly the dealer rep who asked for my feedback on service, stopped replying once I pointed out a quick google search found the same quart of oil for $10 cheaper PER quart. That $255 could have easily been $155 and I wouldn't have said a thing to them or online.
Understanding I should have asked before I went in for service. Lesson learned. Next up 5W-30 dexos1 apparently. |
#28 | |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
